I have now done 4 orders with them and they are a good outfit.
http://www.coolmaxx.com/swmc.html
The 603V(s) are 45.95 a piece; that is at least $5 cheaper than straight from Swiftech and at least that much cheaper than you can get them from anywhere else ( AFAIK ).
If you are going to mount the 603V through the motherboard's monting holes then you will also need a set of MCX603-VSR2's, which can be found at www.swiftnets.com, for 3.95 ( per heatsink ).
