Originally Posted by Bergo
I don't currently own one, but as far as I can tell...
1. the adapter they're refering to is an AC to DC adapter, the froster will accept a voltage between 15 and 16 volts i order for it to run properly, it needs at least 1amp of current to run.
2. had an answer for you on that one, and looked again and got confuzed, wont post until i"m sure, lol
3. Can't say with complete certainty, but yes, it looks to be for a DC fan as it's a 2 conductor wire, although form the picture not sure whats on the other end?
4. The serial port header on your motherboard would be the one jsut above your finger (bottom right hand corner of the bottom most PCI connector) in "mobo plugs.jpg) and it would lead ot "Pc WIRE" as labeled on "wiring.jpg"
