i get my ocz pc 3200 platinum el rev 2 tomorrow :) u think that i'll get brainpower pcb? and how can i find out without taking the heatspreader off? i heard they like more V :) good 4 my booster :D
Hey W00T, I just got mine in the other day and it was 808pcb. To be honest all OCZ PC3200 Plat. EL Rev.2 are on the 808pcb. To find out though is at the ends of your ram modules you'll see at the very egde a marking that will say 808 on it. I have not really tried mine out much yet. settin' at 255FSB 2.5-3-3-10 with 2.6volts.
i got =Quote:
Originally Posted by The Runner
nf7 - rev2, xp-m2500, patriot ram(now!!),9800 flashed'n thrashed, antec true power 550, lrww cpu block, z-chip n/b block, swiftech mcp300, home rad rads w/2x120mm fans - which can be seen here
the xp-m is @ about 2557 (10x243) right now.
yes the mobo is with out doubt the bottleneck :stick:
but as said it's more for a soon to own a64 set-up :cool:
Originally Posted by GravediggA
Excuse me, I didn't check this thread for a while.
Actually we only have Adata Vitesta TCCD rams in here, so I can guarantee you that Adata-Vitesta's 566 and 600 ones uses TCCD and they can handle up to 3.7-3.8 V.
But to be honest, I could not see any difference yet between 3.2 to 3.8.
3.2 also gives me 240 fsb 2225 unstable and 225 2225 stable. :D
And also DDR600 can run up to 275 fsb 1:1 2.5-3-3-5 @ 2.85 V. :D
whats the cheapest tccd you can get with no spreaders?
http://www.oc-wear.de/pd2053558574.htm?categoryId=26
http://www.oc-wear.de/shippingcosts.htm
:) Maybe it is cheap for u, dunno the prices in UK!
Thats are OCZ TCCD but untested from them and without Heatspreaders!
oc-wear.de is the officiall distri. in germany for OCZ!
DDR400 CL 2-2-2-5 @2,6V
DDR466 CL 2-3-3-5 @2,8V
DDR533 CL 2,5-3-3-5 @2,8V
DDR560 CL 3-4-4-8 @ 2,8V
Prefer your RAM naked too huh?Quote:
Originally Posted by Maelstrom2160
Never cared for those heatspreaders. What's available besides Gskill? Would like
to try a detachable spring loaded heatsink mounting system. = heat disipators ... ;)
U looked at my post? :rolleyes:Quote:
Yes, thank you. :)Quote:
That was European page, and haven't seen that brand here in the States.
Ordered the Gskill 'GBLE' from NewEgg.com. With instant rebate it was cheaper
than what other vendors over here are charging. And no silly heatspreaders. :D
Hmmm ... Ok, I want to tell u all something ... Don' buy the OCZ 3700EL PE, they do well on there rated speed ,
but at 270 2.5-3-3-7 2T they give 19000(!!) Errors at Memtest! ;) No, there is noting more, i'm back on my BH5 and all works fine! :eek:
the site doesn't say they are from OCZ, how do you know this? they are really cheap tho .. :)Quote:
U know some other TCCD without Heatsreader? Yes the original Samsungs, butQuote:
Originally Posted by a5h
u can't buy them in europe! ;) And oc-wear have very good connections to
OCZ ... Just 1 + 1 ;)
http://www.ocztechnology.com/whereto...europe#Germany
does OCZ say this or do u just say this?
whats the difference between the different brainpower PCBs? 808, 815, 808a ...which one is best?
also which G.skill TCCD are the best? ...so many kinds.
imho ;)Quote:
hey guys nice thread just read all 17 pages :p: ok i have a few questions?? first off i just picked up a pair of 256 patriot 3200 with the xbl tech. they have the bp815 pcb and the chips have this on them for numbers samsung 440 K4H560838F TCCD now i can tell they have the "F" but i dont see where you guys are getting the 0437 from? how do i tell if i have 37 or later? also i have a pair of eb3500 platnuim from ocz and they have the 808 bp pcb does that mean these have tccd chips also or is it also possible to get a bp pcb without tccd chips? sorry if any of my questions were answered in previous pages...
*edit* is it the 3 digit number next to samsung that you guyare talking about? in my case it would be 440.. also these patriot memorys did 220 defualt voltage in my msi neo2 dual channel 2-2-2-5 before i had to loosen the timmings to 2.5-3-3-5 to go higher.. i havent maxed them out yet so i dont have any other numbers for you. im currently at 240 yeah i know thats nothing to write home about but i will max these out and let you guys know what i get out of these patriot memorys...
thx perc,
Best results seem to come from the LE version.Quote:
Originally Posted by Zanr Zij
Check out the forums on Gskill.com and also the Coolaler forums.
which one of these 2 would any of you guys chose? (they are both relatively the same price):
1. OCZ PC3200 EL Platinum Rev.2 Dual channel 1024MB kit
2. G.SKILL PC4400/3200 F1-3200DSU2-1GBLE 1024MB kit
You have 0440 TCCD :)Quote:
Originally Posted by Perc
Originally Posted by jlccarv
ok so it is the 4 digit nember thats written after the samsung name. cool thx man...
peace perc,
Originally Posted by Zeus
Thanks... ! 1GB or 512MB ( 2 stick ) is better ? Thanks ag'n ! :toast:
2x256 will most likely clock higher than 2x512 but if you are into gaming 2x512 would be a better choice.
For benchmarking 2x256 will be best. ;)
I just bought the patriot 512-3200 XBLK, I was wondering if i can run 3.3 v into them w/ out frying them? whats the average voltage you guy seen throughout this 17 page thread.
