@Hersounds...Did you try the usual boot up routine? ie. Take the battery out for a minute, clear cmos and use 1 ram stick @ one of the red socket.
Nope is this order, but yes i take and later put battery...i do clear cmos,and try with 2 sticks in red sockets ( rams) ( hyper x 1600 ddr 3)
power supply : pc power & cooling silencer 750w quad blue ( 100 % funtional)
force gt 120...
mobo pins in socket really perfect,i don't know what's happen...i buy asus because my last p67 ( gigabyte ) have issues with ivybridge, but this is awesome, i hope today the salesman give me a solution... the mobo at this moment just have hours of live & unboxing!
Check the CPU is working in another board.
yes is the next step today try that and try another 1155 cpu in maximus v gene
http://www.abload.de/img/zwischenablage015zdcj.jpg
Please give me a link to the BIOS.
(p8z77-v deluxe bios 1205)
Where can i find mem tweakit 1.0.1.6 that works with Maximus Gene V
All fine! WAS THE PSU!....RIP PC POWER & COOLING 750 QUAD BLUE SILENCER...you give me years of overclock & fun and stability....rest in peace in the heaven of hardware premium
today change & try PSU TOPOWER 700W and system run normal...so maybe another cases be similar
Glad to hear you got it sorted out. Good luck with it! :up:
thanks guys!! well this is my first run...i wanna now the uefi bios is a lot of settings for try!
Attachment 127433
http://valid.canardpc.com/show_oc.php?id=2397230
never neglect the power of PSU issues...
@ neo_rtr
simple: i never try psu and never ,never think that pc power & cooling die...even plugin psu, the red lights leds turn on in the mobo, maybe that doing spend my time
@Rajia
-VGA
-Intel(R) Graphics Accelerator Driver V8.15.10.2598 for Windows 2008 R2/7 64bit.
Is this driver need to be installed using P8Z77 WS with crossfire. I do not intend to run LucidLogix Virtu.
Thank you
You only need the Intel Graphics driver if you use the iGPU. If you use a PCIe card it's not necessary unless you wish to try the lucid thing.
some UEFI bios OC guide Maximus V Gene for recommended guys?
Cold bug or not. The past 3 days the room has been a bit warm, The pc started each morning with no issues. Straight away. no delay no nothing. When the room is a bit colder. I would say below 21c , it is then when i get the boot delay issue.
Going on vacation now, so not much time to spend on this.
Just my observation. Nothing written in stone.
New bios 1206 available for ASUS P8Z77-V Deluxe
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...-ASUS-1206.zip
P8Z77-V DELUXE BIOS 1206
1.Improve system stability.
2.Improve memory compatibility.
3.Enhance compatibility with some USB devices
They forgot to add "New mini-game to hit Del at the right time to enter Bios"... Still trying to get back in lol.
Edit: Bios seems stable. Same 131Gflops LinX, same temps, ... but it's a pain to enter the bios: smash Del non-stop and it takes me around 10 times to succeed in my case.
Well sadly, I am unable to flash this bios. Every time I flash it, it reads the bios reboots and then all I get is a black screen with the vga LED red and the post LCD reads "94". Tried using flashback as well and same thing. Flash back to 1015 and all good. Thoughts???
Nah, that didn't work. Figured out that 1206 doesn't like my tv card in the bottom slot (PCIEX16_3). Once I moved it, she posted fine. Weird that 1015 did not have this issue though??? In fact, the tv card was no longer recognized and neither was my corsair link on 1206. Flashed back to 1015 and all is well again. I'm guessing that 1206 shuts down some lanes or something funky is going on....
