Don't think it was a single gpu run ;)
mine on dice
http://i82.photobucket.com/albums/j2.../th_P29061.jpg
mine on dice
@ all = yup, thats 6990 on first TEST
6950>6970 1035mhz core 1525mhz mem 1.3v silent air :) 6331
http://i285.photobucket.com/albums/l...g?t=1301451202
GPU-Z 0.53 reads VRMs temps now. You can't believe how cold they are if it's true.
and the voltage is reading correctly now :) bout to test to see how hot my vrm's get..idling at 41C 1000core 1.3v
Someone help me. I'm using afterburner, CCC, gpuz & kombustor. I modded my 2GB 6950 to 1536 shaders. But my limits in CCC are 950mhz for the core. The card is clocked to 950mhz and overvolted and runs just fine.
How do i reach core clocks greater than 950mhz???? I tried the 'enableunofficialoverclockingmethod = 1'. Heheh. I created the HD5xxx series overclocking thread and have done this 1000 times, but I'm drawing a blank right now.
What can i do
http://i56.tinypic.com/2mqqgpd.jpg
I believe what your forgot was in the msi ab cfg. you have to type out the I allow blah blah blah(forgot the exact statement but its posted i believe in this thread and a few others) and you'll get the higher clocks(1350core) etc.
thanks Incredible
Edit: well stability tops about at about 1005 core / 1475 mem
What do i need to push vcore over 1.3? asus bios/smartdoc?
I got a score in the two conditions cayment xt
http://i54.tinypic.com/35bftog.jpg
http://i54.tinypic.com/25qx85k.jpg
Reference Asus HD6950 Unlock on water 1100/1547Mhz :D
http://img13.imageshack.us/img13/8965/unled9u98u.png
By chispy at 2011-04-14
um i may be able to come down some in the 1.25-75 area havent tried yet.
See when i was first trying to clock i could get 950core on 1.175 stock cooler but NOTHING higher stable( i could bench but thats it)
when i put the Shaman on i just flashed to 1.3 instantly made it to 1035 core stable put it to 1.35 and got 1050 stable..benchable at 1.325v 1050 but that was about it. I figure i could get away with at least 1.275 at 1000core maybe even lower but like said never tried. Since thats where ill probably keep it i might go ahead and start lowering it til it becomes unstable.
It was working for my 5850, that's why I flashed it with 5870 BIOS the memory clocks were higher, but here it seems both cards are using same memory voltage, tried 6970 BIOS and no difference in memory clock so I decided to stick with the default BIOS with shaders unlocked only(Ati tool has no problems this way).
@ the_game hmm, not sure man i guess some just aren't capable. Others cant even get stock 6970 clocks so id say consider your self lucky already. But i know how you feel, at first i was pissed i was seeing 1000core+ clocks and i couldnt get over 950 like wtf? Then shaman came along and got that going. Usually i dont achieve the highest overclocks possible but im normally in the small percentage of high clocks most people dont get(with air/water). So i get angry when something cant clock well.
