Bad news for you- you have to depend on your luck- one of the two single sticks I bought was black, the other one green- good news is they worked perfectly together:D- 1134 Cl8-8-8-24@ 1,65V
Just received my replacement WX200UX6G7 kit from RMA. Haven't decided if I'll keep it or not.
Few days ago, i recieved 3 dimms supertalent 2133c8.
What i would expecting to do? Thanks..:D
1077 7-7-7 1.7x volts ...
Could it be possible something like, 1050 7-7-7 with an 920 (210 bckl) and everything on air, stable at spi 32M?
Sorry for the "noobish" question but i need some encourage before starting tests...:D
Very bold plan, General Custer:D- I hope this doen´t end up in desaster:rofl:
Depends on your board, the IMC and particularly on the quality of the sticks, means luck- if you are lucky 1050 could run at less than 1,8V, tests will show- good luck for that:up:
some off topic question...does have this Super Talent kit Hyper IC's? http://www.superbiiz.com/detail.php?...oLSper0v8z1cN6 thanks for answers:)
In my experience STT sticks need a lot of VDIMM for 2000 C7, like 1.70V+. Something like 2100 C7 is gonna take a crazy amount...
Wouldn´t be so sure about that- maybe you just had bad luck- my 1000 C7 need a lot less V than the 2200 C8 and the 2133 C8 I had at 2000 Cas7- here´s an example, just picked two of my sticks and tried it, these are not my best ones;)- and my board is not known for being a good C7 clocker, its much better at C8 and 9- for comparison, I had two 2GB sticks kingston here a few weeks ago, they needed 1,7V with higher TRFC and lots of tuning
http://www.abload.de/thumb/2000c7-7-...63vl11f5h6.jpg
i was wondering, and choosing a new set of RAM for my EP45T-USB3P, i need ot know which of the linked models have elpida hypers and how i would know for future purchases what have hypers and don't.(also which is the better buy)
is it the UX in the model number that determines its an elpida hyper?
link 1 http://www.superbiiz.com/detail.php?...nel-Memory-Kit
link 2 http://www.superbiiz.com/detail.php?...nel-Memory-kit
link 3 https://www.superbiiz.com/detail.php...nel-Memory-Kit
all of the ones you posted are hypers
all supertalent 2000+ with timings of 7-7-7 or 8-8-8 are 100% hypers
Feels good to finally use mine after owning them for months. Very, very limited on time so have not tested as much as I would like to yet but so
far I have gotten 7-7-7-20 @ 1700 with 1.66
i order myself a EP45T-USB3P by gigabyte and The VERY last NO MORE in stock BLACK pcb Super Talent DDR3-2200 4GB(2X2G) CL8 Dual Channel Memory kit - WS220UX4G8
410$$ for the whole deal they even discounted me the motherboard =D VERY VERY HAPPY will tell you my results im going for a 1600-6-6-6-18 ill tell you how low voltage it stablizes out at =D!
They came in but i have no time for testing :( but i had to brag, i pulled the heat spreaders up gently looking in and there ELPIDA MGH-E =D, ALSO Black PCB
2200 2GBx2 Cas8 8-8-8-24
Sorry about quality used old webcam but shows my beauties!
http://img576.imageshack.us/img576/2...2220127761.jpg
Surprised i could get a good shot this close
http://img258.imageshack.us/img258/6...2220229511.jpg
should have results when im done mounting the Heatsink on the new DDR3 mobo, soon!
Hey websmile, nice job, did you try triple channel with your best chips?
I was reading this thread and DDR3 24/7 list thread and decided to buy 2000 C7, what can I expect from them (in best and worst case scenario)? Are they (overall) better than my GT's?
Fresh out of the box so far
http://img218.imageshack.us/img218/9595/dsc034280.jpg
They might be a little bit better than the 1866C7 GTs, but the STT 2000 C7 kit I have isn't anywhere near as good as my 2000C8 GTs.
