Alright Mr Mbreslin! Congrats! :clap::clap::clap:
OK - bring on the big pcmv score now! :shocked:
Yeah right, I'm so far down I can hardly see you and mike anymore. Don't drop a penny from up there it will crush my skull. :x
Edit: So I just played bc2 for a couple hours @4.5ghz vcore/vtt 1.4000, everything else was stock. Except for pcmv, bc2 is the most taxing thing I will do with my computer so I think I'm ok for 4.5ghz 24/7. My cpu hates linx and needs 1.4500 to be stable but I'm in the club so no more of that, hopefully there are no dues. :)
Mr mb - yes, welcome! No dues other than the big $$$ in cost you to get here!
But your not done - oh no - not be a long shot - I'm still checking the orb for your new pcmv PR!
Mr Zalbard - in the OP please change my 980x batch from 3003B827 to 3003B287, thanks!
http://img72.imageshack.us/img72/8117/4500linx.th.jpg
Task manager shows 100% load because I had restarted BOINC WCG.
EDIT: forgot batch#: 3003B331
980X@4563.9MHz 1.435V(BIOS1.375V) 6C/12T
【CPU】Intel i7-980X 3003B396
【M/B】eVGA X58 Classified 760
【Mem】PVT36G1600LLK
【SSD】Intel X25-M160G2
water-cooled
CPU: EK-Supreme - Acetal
VRM.IOH.ICH: EK-FB EVGA X58 CLASSIFIED
MagiCool XTREME NOVA 1080 ( 9 X 120mm) Radiator (Fan 12cm500rpm*9)
KOOLANCE PMP-450
I am a Japanese PC creator
http://blue.ap.teacup.com/kazukun/71.html
http://blue.ap.teacup.com/kazukun/74.html
Hey Deadly :) just a simple water cooling.
Hi
I have recently upgraded to 1366 platform from 775.. so still a nubi on OC these .
I hope you can add me to the 4.5 LinX Club.
I have just completed 20 passes at 4.55mhz(HT off) i7 920 (3938B023), 1.528V vCore CPU-Z Load 1.84V PLL, 1.325V VTT, 1.64V DRAM.
Getting close to the limit of my WC system, room temps 80F.
Although I have started to prime 4.59hmz.. I think i am BCLK limited cant go over 219 on this mb. R3E in my sights when they are out..
920 batch 3925A260 HT on
http://gallery.ducatispot.com/image_...16678_full.jpg
rob
mw - very nice! - nice low temps - what are you using for cooling?
SteveRo;
Thanks...I took advantage of a cold front that came through and opened the windows so the ambient was about 16-17C. If that had not happened, and I ran the chip at 4.5 with the windows closed at 23C, I would see core temps around 72-74C. Still, I think I can eek another 30-50mhz from this 920.
You can see my build with my signature link, but I've got a MountainMods ascension with cpu/mb/ram cooling by 2 DDC 3.25 in series with res top/acrylic res going to two 3.120 XSPC and one 1.120 XSPC rad; currently not push/pull, but planning. Usually, I can leave the fans at 900-1000rpm and the only
thing I can hear is the GPU.
rob
mw - excellent cooling!
Hey, SteveRo got our 980X 3003B287 twin to 4.531 HT on.............:up:
Low gigglybops though :shrug:
(Booted into 'Diagnostic Mode' and quickened my memory timings :shrug:
http://img402.imageshack.us/img402/883/capture28.th.png
Nice work Mr Newhit!
Really nice low temps also!
Yep, B287 seems to be a good batch.
Many of us are getting low gflops with the 980 - might me a linx problem.
Great job, everyone! :up:
Keep pushing your CPUs! :D
2 weeks ago, a couple of hours Prime95, but forgot to run linx :).
http://img535.imageshack.us/img535/8...a37c614e42.jpg
HA-HA...bottom of the list...can only go up from here.
reminds of the joke: what do you call the guy who graduates last in his class in medical school?......Doctor.
rob
Wow The gamer how you do that Golden batch :P with what mobo was that?
The CPU is crazy but the second core is too bad. I can pass super pi at 5.8GHz with only one core enabled.
http://img219.imageshack.us/img219/9...b553d31844.jpg
Can run prime at 5.4GHz with the same core but the second one is dying 200Mhz lower not only at prime cause of the heat but super pi too :(. If the second one can pass super pi 1M at 5500MHz the first one can pass it at 5700-5800 with the same Vcore.
The MB is GB EP45T Extreme, NB is air cooled for both prime and super pi :).
Btw the cooling is SS phase change and the CPU is going above 0 degrees, no cascade or LN2 :).
been trying out a lot of different overclocks, benching the crap out them trying to find the right RAM speeds/ CPU speed combination, this is the lowest RAM speed overclock I have tried, and I forgot to drop the VTT down from where it was needed to run 2200 MHZ stable. also higher RAM speed seems to raise G flops.
Batch 3003B
rig in sig
19C ambient temps
while running Linx
http://i18.photobucket.com/albums/b1...Capture-12.png
after completion
http://i18.photobucket.com/albums/b1...Capture1-1.png
Very nice justin!
When are you going update your pcmv score - long overdue - and with 4x x25m - a real shame!
Thanks.
I had first place for like 2 days. lol I will wait till Intel's next SSD before I attempt it again. :D
When I had 8 Intel SSD's on a LSI 9260, I should have posted up my scores, but they were not enough to take the top.. :p:
