Originally Posted by
elsupremo
Guys,
I have a 760 with a 920 C0/C1 chip (quite a cruel joke, btw - just bought it and quite some bad luck to get a C0. Didn't know importance of D0). Trying to get to 4.2 eventually, but at 4.0 for the moment and stable (IntelBurnTest maximum burn with many runs, superpi, benchmarks, etc.) except one thing - sometimes, like entering a game, a USB (such as my G15 keyboard) will disconnect and reconnect. This does not occur at stock. I suspect it could be due to one of my voltages being low. Please help me figure out which setting to adjust to stop this from happening, as it sounds like a slight bit of instability.
I filled out the template with all the settings just so you have all the information. Thanks for any help you can give on this issue!
Mother Board ( EVGA X58 Classified E-760)
Drivers (Newest from EVGA site)
Bios ( Newest from)
CPU ( 920 C0/C1)
CPU Cooler ( Cooler Master V10 )
Memory ( Corsair TR3X6G1600C9 XMS3 6 GB 3 X 2 GB)
PSU ( Corsair HX1000 )
GPU ( GTX295 )
Drivers ( 185.85 )
Operating System ( Windows XP 32-bit SP3 )
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 191 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 800Mhz / 2:6 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 74 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.375 )
CPU VTT Voltage ( +300mV )
CPU PLL VCore ( Auto )
**IOH PLL VCore ( Auto )
DIMM Voltage ( 1.62V )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( Auto )
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
**VTT PWM Frequency ( 250 KHZ )
**CPU PWM Frequency ( 800 KHZ )
**CPU Impedance ( Auto )
**QPI Signal Compensation ( Auto )
ICH VCore ( Auto )
*PWM Frequency ( Not Used on Classified )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s )
OC Recorvery ( Disabled )
