I don't know specifically, but it was the only LinX test my system would fail (BSoD) at. I presume because it places the largest load upon the CPU/RAM, and the larger the problem size the longer the duration of the load upon the CPU. Just like IntelBurn, CPU load alternates between 100% and 0% loads but the duration of the load increases as the problem size goes up.
Screenshot:
IMG Link (1920x1200)
I am still in the process of lowering my VTT & IOH voltages to find the lower limits, so far I'm at 1.42 vCore, 1.20v IOH, 1.30v QPI/VTT, 1.66v RAM. Several hours each of LinX, Prime95, and Left 4 Dead are stable at the above settings. Also used Memtest to verify the RAM. Hyperthreading is ENABLED. Uncore of 3800MHz is extremely unstable, I can't even run it at Renegade's frequency! Once I bottom out the voltages I will try an Uncore of 3600MHz and see how it goes on minimal voltages, but I expect 3400 will by my 24/7 setting...
Even with a QPI/VTT of 1.38 and IOH of 1.30, and uncore of 3200, if I lowered the Vcore to 1.40v the system would BSOD ten minutes into 5GB problem sizes in LinX. I'm not sure what else is left to try, the only thing I have not attempted were the PLL settings or maxing out the CPU Clock Drive setting. I am very happy to have a fully stable 4200MHz OC with these RAM timings, unusually high vCore or not. :cool:
