Originally Posted by
Zucker2k
Are you sure those settings are maxing the GPU? I don't think those settings are very gpu-bound. In any case, your last statement takes nothing from what I said; if the i7's HT is the culprit, meaning the cpu is taking a negative hit, the results are still better than the PHII :yepp: And if the gpu is maxed, then are you saying it takes only 22% of the processing power of a Ci7 at 3.6ghz to max the a 4870x2 with GTA IV? Or are you leaning towards the unknown? :shrug:
