Currently I am looking at possibly water cooling two GTX 280's and a core i7 920. I already have a MCR320 mounted on the top of the case.
It is cooling my current rig that is in my sig, but I believe it is at its limits.
I was going to get a second stackable MCR320 and mount it on the top also, it should fit but will be close. But with this setup I'm afraid it will not be as efficient as having the two radiators separate.
Would it be possible to mount a MCR320 in the front of the case? I want to keep the modding down to a minimum if possible but I don't mind doing some.
Another idea I had was to mount the two MCR320's on top and also add a 160mm radiator on the back which should give me enough cooling.
Current fans: 3 Scythe SFF21F PUSH config
Any recommendations is appreciated thanks!
