Made another comparison with CT 0.97 and RT 2.1
Idle temps are detected with 1c difference between programs (RT showing 1c lower compared to CT) by using a ++ calibration on the idle temps.
But during a certain amount of heat generated the CT readings pull ahead by 2~4c difference from RT ( again RT reads lower with ++ calibration )
I tried booting my system to 266x6 at 1.275(lowest VID possible on my Q6600 G0) resulting in a +1/-1 reading on CT & RT. ( on 15mins of Prime95 v25.6 SmallFTT )
Returning to my OC settings of 400*8 @ 1.335v ( bios volts ) I noticed that RT's reading is comparable to CT upto 49c only when both programs start to indicate any value of 50c, CT seems to start pulling ahead upto 4c difference from RT.
Basing on my unreliable room thermometer here, im getting 31c for my ambient. Using RT with 0 calibration shows my lowest core at 29c, + 32 & ++35
http://img411.imageshack.us/img411/6670/ctrtsh6.jpg
Loaded
http://img174.imageshack.us/img174/8825/ctrtidleiq7.jpg
Idle
Since RT detects the TjMax of a Q6600 at 95c w/c a lot of people believe the TjMax is 95c instead of 100c or 105c
i would assume that the 0 calibration reading on RT is the correct temp since im getting the correct temps when i deduct the delta to TjMax with the current TjMax detected
