Achim, what did you measure for your X2 BE? YOu had an X2 BE EE didn't you?
Don't use autoclock. It is quite buggy. Use the manual oc. :yepp:
SP3 RC: http://www.microsoft.com/downloads/d...DisplayLang=en
Thaks Achim. Those numbers will come in handy. ;)
Hi There KTE, Compliments of the season to all. No news on a new BIOS for the MSI? How the system performing under SP3 would you say there is major improvements and worth going back. I know overclocking a person get more points on XP than Vista but what you reckon? And what about XP X64
Here's where to get the latest MSI K9A2 Platinum BIOSes from: http://www.msi-forum.de/thread.php?t...tuser=0&page=6
Move onto the next page and there is a new BIOS release: v1.22
I've not tried it yet but should do by Saturday.
SP3 performs better than SP2, for me it is more stable too. XP 64b is better for K10 than XP 32b. Best wishes to you too! :)
Thanks KTE. I read the read but see this one has the Errata fix and cannot be turned off in the BIOS. It fixes the Phenom /1066 DDR memory isssue- so that good but the loss of speed due to the fix not good. I heard that with the new AOD the "fix" can be turned off, if so ,where
Swanie, At the top of AOD (tool bar) on the left hand side you will see a circle click on that, the outside of the ring will turn yellow (turbo, but not sure what it does)... Click on it again and the outside of the ring will turn red... I'm pretty sure that disables the TLB patch!! :)
I don't have a phenom yet, but I have read that that is how AOD disables the patch...
I hope it doesn't have the "fix" hard coded. As for the TLB turn off, I was thinking it is that button as well, but I'm not sure until I try it now.
@KTE....What Phenom are you currently using ATM?
ATM?
Blacker Edition...
Core 2 Duo :D
Where Prey Tell did you get that Old Boy:p:
I have the X2 BE-2300 here. Have to set it all up yet.
Then comes the other AMD CPU. Stock still non-existent for me, prices heavens high and I don't like paying a dime. ;)
They fly to me through my window while I lay to dream.
Eh?
Santa missed his train so he sent Peter Pan to bring them. :)
KTE, possible to try out the 122 bios for us please?
I don't have a Phenom to try it sorry. Only an X2 here.
Phenom I need to collect.
hi kte
thank u for your reply in http://www.xtremesystems.org/forums/...48&postcount=6 that helps alot..
if i set the AM2+ Custom P-States to what u said, could i then use AOD to do everything else? im asking because i can't use my hands has im disabled so its very difficult for me to do stuff in the bios...
You're welcome. :)
Yes you should be able to do everything within Windows (AOD). AOD is the main tool you need here. Is your CPU on stock heatsink/fan?Quote:
I didn't know. Had I known earlier, I'd have wrote more in the linked post. :)Quote:
What are your stock core temps gareth170? (you can check in AOD tabs)
Yep, about right. :up:
Not sure if they're specifying case operating temp or internal core temp both of which can have a delta of ~15℃. You should avoid getting above 55℃ for 24/7 usage though.
Ah the BE is DOA! What a :banana::banana::banana::banana:n PITA!! More delays :mad: :mad:
