Made pencil vmod, new vgpu is 1.512V :D.
This the results:
Freq. GPU: 1012mhz
Freq. RAM: 1301mhz x 2
3DMark06:
http://img98.imageshack.us/img98/252...1296so5.th.jpg
Crysis Bench @ 128x1024 all very high. DX10 on vista 64 bit:
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 110.36s, Average FPS: 18.12
Min FPS: 10.60 at frame 1942, Max FPS: 23.63 at frame 860
Average Tri/Sec: -12040729, Tri/Frame: -664394
Recorded/Played Tris ratio: -1.38
!TimeDemo Run 1 Finished.
Play Time: 103.22s, Average FPS: 19.38
Average Tri/Sec: -12659318, Tri/Frame: -653346
Recorded/Played Tris ratio: -1.40
!TimeDemo Run 2 Finished.
Play Time: 102.75s, Average FPS: 19.47
Min FPS: 10.60 at frame 1942, Max FPS: 23.67 at frame 983
Average Tri/Sec: -12684731, Tri/Frame: -651668
Recorded/Played Tris ratio: -1.41
!TimeDemo Run 3 Finished.
Play Time: 102.24s, Average FPS: 19.56
Min FPS: 10.60 at frame 1942, Max FPS: 24.34 at frame 985
Average Tri/Sec: -12775948, Tri/Frame: -653119
TimeDemo Play Ended, (4 Runs Performed)
Max temp (@water cooling) is 40°C.
It seems to be RS.
