One question: with this board, with C1E and EIST enabled, when you change the vcore to 1,50v for example, at idle, what does the processor do? Change multiplier+voltage, or only multiplier?
Thx :)
Thx :)
Cedar Mill 533MHz FSB works on this board as long as you don't touch any of the memorysettings (including dividers) :)
So it's quite funny to test a $30 Celeron together with a $250+ mobo :D
http://home.hccnet.nl/J_Bongers/maximus/7473.png
7473MHz validated @ ~2v
validatior link
Also a U20 1M:
click
19.860s @ 7309MHz ~2v
validation link
Cooled w/LN2 ofcourse
pic of the system (1600x1200)
Not really. maybe if you could post what bios says it set timings to...need to know which ram you are runnig as well.
Errors here happen at same address regardless of what ram is installed. Tming adjustments make only minor difference..still errors, but get less errors...errors are lessened with an increase of chipset volts..haven't tried over 1.45 tho...I see 450 @ 1.7v here tho..so more playing to be done. haven't tried two sticks in other slots to see if it's the slots either...
:shakes: :shakes:
Kind of off topic but, will the P35 and X38 both work with Nehalem CPU do out Q2 2008?
P5k box says supports 45nm cpu's, so you'd think so...
Not tried memset or prime yet but 32M runs fine. Ballistix PC8500 and Cellshock PC8000c4. Just set vcore and vdimm (probably could do with less) and 5-5-5-15 rest = auto, just to see if it would run:
http://img.photobucket.com/albums/v6.../32mloop12.jpg
http://img.photobucket.com/albums/v6...2m4096done.jpg
ok, just got the g.skill 4gb ddr1000 from newegg, and it booted up first try, stock settings at 1066, that seems to be the limit, but for 4gb's its a great kit
@loc.o
You wc in fusion block?
Stock heatsink no water or fan. Its on me desk though not in a closed case.
This is what i have so far..............memory is the new g.skill DDR2 1000 4gb set
http://img90.imageshack.us/img90/6341/95474892bq6.jpg
Nice GAR, can you reach 550Mhz? Latency doesn´t matter here. And also how they respond to voltage?
I havnt tried any higher but im sure it will do 550, most likely that will be the max for this kit, either way i like it very much, im happy for 200 bucks couldnt get better.....as far as voltage, doesnt respond well, 2-2.1 is where you want to stay. 2v is enough for this kit.
loco how high can you go on 4 sticks ty
Im Lovin this board.........anyone else with me? i think im going to ebay my 8800GTX next month and go for a 2950XT crossfire setup.....only if they can proove to be good cards.
Nope it's also ment to be in LGA 775 but has it's own NB built in
i heard its using socket 1208 or something like that.
