NICE TO HEAR DUDE NICE STUFF :)
Thanks. i see you have an 0308WPMW. mine are 0310WPMW.
you gotta love'em.:thumbsup:
Yeah I just got an Abit NF7-s rev 2.0 just working on it can do 245FBS but not so stable man but I am hoping around 230 maybe HEHE did the L12 yesterday I couldn’t even do 200Fsb stable, and couldn’t even boot at 220 lol
Check this out.this is @ only 1.75v:D
How about this?:)
Nice I can hit 245 HAAHAHA
:toast: :slobber: Ill have to try harder!:thumbsup:
That's great results guys
Just wondering if I put an AMD HSF on the NB on the Nf7-S will I see more stability? in FSB ?>? Cheers
i think so, the stock hsf on the nb is rather weak so more cooling can never hurt
so to do the 8 bit mode am i supposed to connect the pins with the white lines on them in the picture and for the l12 i can just connect pins on the bottom right ????
Putting a HSF will help you overclock a little more. I realized that early. Also, I might be a good idea to lap the NB that way you will have better contact with any HSF. This will also lower you temps a few degrees.
Thats what im running on my NB while my chiller is down, a factoryQuote:
Amd 2100+ hsf.:thumbsup:
DID IT HELP ?
I dont think my cpu likes high FSB :rolleyes: :confused: :(
I'd say about 5 or 6mhz. thats about the same increase i saw with my epox & the same hsf.Quote:
DID IT HELP ?
hey guys this thread is great and really helping out i tried the mod by inserting some phone wire into the socket for ah30 and a vss i guess it booted up as a 2700 in the bios but when i hit save and exit it wouldnt boot up again till i took the wire and cleared the bios anybody have any idea why?also second question the stepping on my 2100 is airga so that means its a tbred A correct is that determined by the second a i just wanna know because im gonna go searchin for one and id like to know how to tell if its a b core by lookin at it cuz b's are better overclockers right???? thanks for all your help.
xxxxA is a tbred-a, yes.
Yeah u have a A core not a good @
look at mine cpu look at the underline it's a B at the end
kool thanks would yu recommend i buy a 2100 or a 1700 ?
or would an unlocked 2500 be better??
thanks for your help
any of the u poster r good 1700xp over 2100xp and 2500xp over 1700xp :)
EDIT: LOL
so the 1700's are better i dont get the 2nd part about the 2500's
His order of preference (best first)-
1 xp2500+
2 1700+
3 2100+
If I was going to replace my xp1800+ @2.4Ghz (done 2.5Ghz with cold water) 2.03v; then I would consider the xp2600+ barton. I would imagine that they would generally guarentee a latesr core which *should* be a good thing.
Can you get me the complete stepping? :DQuote:
Originally posted by pc ice
i have been playing with my new barton 2600 and it do's 2.520 @1.8v on water and 2.740 benchable @-20 underload @1.8v
but it is a newer chip and it is locked but it do's great on it's defualt multi so i kept it so it's a toss up on buying a newer locked chip or a older unlocked chip. i would think.
whos stepping mine is airga
