You should be running smal fft's instead of large for CPU stability. Also you should use prime95 instead of orthos. it stresses all 4 cores with the 1 program. I can pass orthos for hours yet fail prime95. I think orthos may be outdated.
WHERE ARE ALL THE DOUBTERS NOW HEY
4GHZ prime :shocked: even if not for too long :D
Nvidia User Group Member
That explains your post.:rofl:
I have 5 1/2 hours prime @ 4Ghz http://www.xtremesystems.org/forums/...&postcount=389. Basically shut it down because I was tired and didnt want to leave it unattended. I am sure this chip has allot more, but need another board.
I will wait for X38 tho. I am happy with 4Ghz ;)
ROFL heheheh
yeah i posted the first G0 quad results with 4GHz+ 3D benches from my contact but was afraid it would be much better than retail
it turns out it is on par with "good" chips
err not sure i get this post :p:
[EDIT]holy :banana::banana::banana::banana: that was on 680i chipset >>>> LOL i now know what Forsaken means LOL >>> ERRR i'm on the beta testing program and required to have that in my sig but i'm no cheerleader man common now
I've got my Q6600 G0 @ 3.8 GHz (1.5625v Bios, 1.5v Everest) benching Cinebench. It's hitting 62c, so I'm sure its not prime stable, but it's on air with my U-120-X. I'm not comfortable juicing it with 1.5v, so I'm leaving it there.
It's running 3.6 GHz (1.45V Bios, 1.39 Everest) Prime stable as my 24/7 clock.
Stepping? :/...
dinos22: not everyone does 4ghz tho.....pure luck.
Just try small FFT, I admitted my past experience with other CPUs was wrong,
it failed in a few minutes at 1.58V when stressing small FFT, raised to 1.62V, 30mins passed the dual orthos.
Also try dual orthos and prime95, no obviously difference, as both not failed at 1.62V :D
1.62V,@ 4GHz Small FFT 30mins dual orthos passed
http://img184.imageshack.us/img184/6...224620auc5.jpg
hmz so what is a better test for RAM: Large FFts or Blend?
Phucked if I know, but if you take the ram out of the equation (meaning it's error free and stable - stock) and run your cpu overclock using small ffts - priority-9 it's more likely to pass this than it is when running large ffts priority-9. Why?, I have no idea, but quite a few people have confirmed these findings as well.
Best idea is to run Small, Large and Blend if your going for full 24/7 stability. 10 hours each :)
My quad runs about 5c hotter with small FFT compared to large. Plus if you look in the task manager you'll see that small FFT barely uses any RAM(because it fits in the L2 cache) while large FFT will use every available MB. So it's pretty obvious small FFT is more stressful for the CPU and large FFT for RAM and FSB. But they are not mutually exclusive. Failing large FFT does not automatically point to the RAM because the CPU is still working plenty hard. Same with small FFT.
When I OC I start with the highest CPU muli and run the RAM underclocked with loose timings and then run small FFT to test the CPU. Once the CPU OC is finalized I jack up the FSB and RAM and run large FFT to test those. After everything is OC'd I run blend mode overnight for a thorough workout.
Trying to determine lowest stable Vcore for 24/7 o'c on air - 8 x 401 passed >3H Prime95 small FFTs at 1.30V BIOS, 3.2GHz looks good enough for use on my unmodded P5W (stupid linked Vcore/EIST/C1E options) at default Vcore even with droop.
http://i173.photobucket.com/albums/w...00V_Stable.jpg
Torture test your CPU with Prime95
http://www.playtool.com/pages/prime95/prime95.html
but anyway, practice is more important :D
after seeing this thread and other results on other forums i can tell you right now it isn't really THAT much of a luck
look at 3.6GHz stable results and you will see that most of these are stable between 1.37-1.41v at that speed
and then add 0.05v for every 100MHz OC and as long as your cooling can hold out you will be able to reach 4GHz with around 1.57-1.61v somewhere :D :eek: :shocked: :D :up:
i got one of these CPUs incoming tomorrow :D week 27 :D
in australia we are buying week 27 and 29 and they are so far doing 3.6Ghz 1.4v
some suicide shots :D
Config:
CPU: Intel Q6600 L724A784
MB: Asus P5K Premium
RAM: Team Xtreem DDR1000 C5 1G X 2
Display Card: Nvidia 8800GTS 640M cooled by EK Block
WaterCooling + air conditioner direct blowing
Laing D5 Pump
BlackIce GTX Extreme 240
Dtek FuZion
266strap, 4:5 divider, 1.7V Vcore
4320MHz passed Superpi 1M:
http://img393.imageshack.us/img393/8...perpi1mha9.jpg
4367 CPUZ Validation:
http://img184.imageshack.us/img184/6...idationvi0.jpg
excellent hahahah
