its probably a noob question, but here goes...
FSB Strap To North Bridge(Mhz) 333... is responsible for what?
and DRAM Frequency is this the setting for the strap that the board uses?
maybe others can help me get a grsp of things...
choose 266 strap as it is a fair bit faster than 333 :)
and as i said already ONLY increase voltage if required for stability
now a 3.4GHz Quad is a monster rig so i would try and have all voltages to their minimum values or closest to that
PLL does affect FSB but only when you start reaching limits....and not always 100% but it also affects the stress on the CPU as you've seen with higher temps....but such temp change is more than i thought :eek: heheh
try reducing vcore a little too...........you should be able to shave some more off :D
i tried other multis and was able to boot to 490 x 6 but far from stable but can do spi 1m at 480 x 8... still looking... thanks guys. needed that.
Im not trying to be rude by what is the purpose of a post showing 500 fsb?
to show the power of overclock of this excellent motherboard And because I was having difficulties in obtaining the fsb of 500mhz.
My point is that 500 fsb is the norm and these boards have gone above 600fsb.
No big deal I was just curious if I was missing something ;)
At last someone with the same problem as me, I had just made a seperate thread about it here
Its definatly not a temp problem, its only in the late 40's before my chip switch back to x6 multi from x9 when priming. Its some problem with this 0603 bios and G0 quads.
Not sure what to do as I cant see another bios coming out any time soon :( I would have thought more people would have this problem though.
That's a weird problem lads, I always leave EIST off as I overclock and fold always when my PC is on and I was told to always turn off EIST when overclocking
Also I wouldn't trust CPU-Z for a correct value of CPU voltage, better go Everest or even Asus Probe though best thing still is a digitam multi meter....
i gotta tell ya, those asus boards are just straight up hideous in color :lol:
Has anyone got a G0 stepping to work with a bios pre 0603 ?
Cut somebody tell me which bios shows allso minus degrees ? I have 0603 but it shows only 10 degree if i test it with my cascade ?! it must be around -80 to -90 degree !!
Regards
SPLMANN
anyone have a problem getting this board to push 4GB of mem over 1000Mhz?
It becomes very unstable over 1000Mhz with 4 x 1GB PC2-9600 modules...i did not have this problem with my 965 Commando.
No problems here, running 4GB of Ballistix 6400 @ 1142 @ 5-5-5-15 with 2.2V.
On my 965 Commando, I could run 4Gb at 5-4-4-12...
On this P35 P5k, i have to use 5-5-5-12....
Anybody knows if there are compatibility problems with Corsair CM2X1024-8500C5D rams?
If i install these rams the system doesn't boot.
Thanks!
I do not know about Corsair, but I cannot get these f*cking Patriot 9600 modules stable on this board over 1000Mhz! I am trying everything and I cannot get my board stable.
There has to be a compatibility problem with my RAM and this board.
This P5K DLX is the WORST board I have ever owned and I regret buying this POS.
Chances are, there probably is if you are having trouble.
no prob, I use them set to 1150Mhz 2.15-2.2v on this board without any issue.:up:
At least my Dominator version..., I think your corsair modules are incuded in this list ftp://ftp.asus.com.tw/pub/ASUS/mb/socket775/P5K%20Deluxe/P5K_Deluxe_WiFi-AP_QVL.pdf
Q6600 G0 488x8 24/7 Watercooling P... mod vcore :up:
PC 8000 cl4 Cellshock 5-5-5-12 2T 2.45v 1220MHZ
NEW bios 0704
Asus P5K P35 (vanilla)
http://dlsvr01.asus.com/pub/ASUS/mb/...5K/P5K0704.zip
