Great LCD man
Great LCD man
My new Workstation! Couldn't resist with all these $3000+ stations.:yepp:
[IMG]http://i245.photobucket.com/albums/g...r_Revenger.jpg[/IMG]
Updated from page 1 or 2.
http://www.needmoreboost.com/wes/room.jpg
Edit: Stacker 830 is new, CM690 houses Gaming rig in sig, Antec houses Sammy in sig, Ultra Aluminus houses the workstation in sig. The comps under the desk are an old Duron 1.2ghz and Axp 2100+. Laptop is my work laptop an HP. The rest is self explanatory.
Bought that 22" Samsung on Black Friday from bestbuy for $220 =]. My PC sucks! Its still only a pentium 4 2.8ghz. Bio's says I im getting 92 degree's in temperature for my CPU, no way I can lower it down so I use that big fan. It helps lower the temperature by 2-4. I am going to build a new PC once I get my financial aid in a few days :up:
http://i145.photobucket.com/albums/r...k/DSC00108.jpg
http://i145.photobucket.com/albums/r...k/DSC00111.jpg
I agree
Remove the dust, apply new thermal paste and it should be better :)
unless you have an old C0 preshott
De_dust 3 :eek:
I thought I had a dust problem.....
:rofl: Hahah, I knew I would be laughed at. Anyways, I have no thermal paste laying around and no air spray to clean that dust. Ill rearrange the wires though.
EDIT: I cleaned out the dust with some cue tips and the temperature went down to 58-60 degrees !!!!! Geez, I didn't think dust would have made it that bad.
Or you could wait a couple more years and start planting flowers in the bottom of your case. WOW now that's Xtreme!!!
I still have the same components, but as talked about in a previous post I split my noise/heat components up. I have a tech station away from my desk with just a small LAN case on my desk. I had to make a custom cable for molex power, USB, reset/power buttons, and SATA. Came out okay, redid my computer room and even cleaned the carpets. Sooo here are the pics.
[IMG]http://i245.photobucket.com/albums/g...orkstation.jpg[/IMG]
[IMG]http://i245.photobucket.com/albums/g...kidPCfront.jpg[/IMG]
This one is kinda fuzzy, sorry. You can see the working parts in blue on the pull out shelf. The LAN box on the desk is the CD/USB/buttons box.
At night
[IMG]http://i245.photobucket.com/albums/g...tationdark.jpg[/IMG]
The MATX has no vid, or sound connections. Here is a close pic:
[IMG]http://i245.photobucket.com/albums/g...dPCBoxback.jpg[/IMG]
Here is the cable that connects to it:
[IMG]http://i245.photobucket.com/albums/g...econnector.jpg[/IMG]
no no no... the ash tray near the gamepad will not do!!!
it gets in the way of the game pad and you're gonna have ashes galore...
go to the local supermarket and pick up an aluminum bread mold... velcro or foam stick that thing to the center, right in front of the keyboard...
that way... you dont have to worry bout ashes in the keyboard and a big enough ashtray... dont even have to take the cig out of the mouth...
:D
Bad camera, but this is current setup ;)
http://img245.imageshack.us/img245/3...2007500ab9.jpg
http://www.aci.on.ca/~arvinz/_MG_0935.jpg
http://www.aci.on.ca/~arvinz/_MG_0950.jpg
Hi Where U can buy Matrix posters?
Whoa Darius, I LOVE YOUR ROOM!! Except for the toy figurines. :up:
Toys... Those are not toys, they are hand painted collectables, and some are prolly worth more than your CPU/Mobo (maybe more) combined. They are man-geek dolls of the highest caliber.
Now having a cute fake girl in a sig gets me.....:D
