Originally Posted by shawn1998
Runnin 4 gigs of OCZ ATI CERT DDR800, no problems......:cool:
really nice info Jaan !
wich vmods have you performed on the motherboard ?
is there anyone that use the coaxial line out for the audio?
I've connected my speakers but it doesn't work
help me
thanks
I'm using it with no problems. In the Intel Audio Studio, do you have Digital Output Format set to something other than "Inactive"?Quote:
Originally Posted by diablos
I just realised that i didnt change the memory reference frequency in the bios. I changed the memory divider to 1:1. Is the memory reference frequency only for reference in the Main Tab in bios or it is doing something usefull?
The reset the bios thing is barbaric these days, but the low voltage default ram thing is getting to be a big problem. I have had this happen lately on dofferemt sets of ram on 680i's, and P5B's. It happens more often when you have run ram for a period of time at 2.3-2.5v. It needs to be fixed as does that bios clearing issue.Quote:
Originally Posted by malficar
my idea of a good high end memory suppler is one that codes very conservative settings into the SPD in their memory so that it is able to boot at default settings and voltage in any board. I have ocz ddr2-1000 which is the latest rev of Micron D9 (which i believe is currently thought to be the best performance ddr2) and it boots perfectly at stock voltage.
the downside of booting at higher then stock voltage would be that it could possibly kill sticks of memory that just can't take higher then stock voltage. I'm leaning towards the fact that the SPD settings on most high end memory should be setup more for initial boot then for any hopes of performance. If the memory companies can't get their stuff to boot at stock then they are the ones who need to rethink their approach.
Originally Posted by theonlybabyface
ouch, even in compatability mode? H m m What to use then? IDCC work in Vista?
has anyone measured the (unmodded) vcore and compared to setting in bios?
it's in my projects for the weekend (testing with conroe and kentsfield)
no, it is set on inactiveQuote:
Originally Posted by gtj
Well that would explain why you're not getting anything out. :p:Quote:
i must selected other choice and not inactive?Quote:
Yep, either PCM or Dolby Digital should work fine.Quote:
but my speakers are 2.1, it's the same?Quote:
Yeah, it sets the ratio from BIOS. Well, mostly. A few times I set 333/667 and got 4:5 instead of 1:1 but it's been pretty reliable mostly.Quote:
Originally Posted by shogo_ca
PCM would probably work better for you but you can try them both without hurting anything.Quote:
ok, now work fine
thanks everyone;)
i dont think 2.0vdimm could kill a value ram or any ram rated at 1.8v.. my teamgroup 6400 3-3-3-8 2.0 to 2.2v booted fine at 1.8 because the timing were loosed to 5-5-5-15 and ddr 533 by default...
Any cold boot problems with this board ? The kind you have to hit reset twice to post when overclocking.
no coold bootQuote:
Ya'll lost me there. What would I need to change to get different memory dividers and which is the best?? Man I swear DDR2 is complicated....:rolleyes:
If you are looking for the most recent BIOS and software for the BX2 follow the below link. Select your OS and go.Quote:
http://downloadfinder.intel.com/scri...ProductID=2578
is it important which SATA port I use? there are those 4 black ones and the coloured ones belo them (blue). at the moment im using the black one.
Thanks for your reply.Quote:
Originally Posted by Supertim0r
My BAdAxe1 has allways had cold boot issues starting at FSB 340 and above.
Also even at default FSB the onboard NIC will not show up in the BIOS and in windows with out 2 reboots. So I had to ask about the BX2
