585 with X6 But I dont know FSB max of this motherboard, it s a new one.Quote:
Originally Posted by loc.o
And i havent try other bios than 1004.
Originally Posted by Pt1t
very nice.. I will look forward for your results.. :)
:woot:
I am very sad to say that I may have killed my xeon :(
I was having some freak things happen with my RD600, and it would only boot @ stock, sometimes even freezing in the bios @ stock...
Throw it in the Commando, no post. Code on the back was:
"CPU INIT" :*(
they sometimes survive manQuote:
Originally Posted by fhpchris
just give it a bit of a rest and try again....clean in give it a few kisses...hell it's valentines day you never know ............otherwise :(:(
I am pretty sure that it is dead :(Quote:
Originally Posted by dinos22
1.67v on water on a B chip might be pushing the envelope a little too hard , but I think this is a RD600 related failure reallly. I could not even reach what my AW9D would run, and my results kept getting worse and worse...
Came here to seek some advice about my 3060.
My specs:
L629A780 3060 366x9@1.48v
P5b Deluxe
Tuniq tower 120
Corsair 620HX
I'm trying really hard to hit 3.6 and i've hit a wall already at 3.3ghz. I can only run 3.3ghz stable at 1.43V. 1.48 set in bios. With the side panel open, I'm running at ~60C Load ~50Idle. Reported in Coretemp/TAT. I can boot into windows at 3.6@1.55v but fails orthos immediately. Raising Vcore doesn't help in this case (up to 1.65v in bios). 3.4 wont run orthos for more than 2-3minutes. Min volt. required to boot into 3.4 was 1.45v raised as high as 1.55v but can't get it stable. I've remounted the Heatsink about 6 times now the past month, all temps were the same except one time when i put too little AS5 and idle temps were in the 60's.
This all points to a Heat related issue, Could I have gotten a bad chip? Ambient temps in the room is about 70F. Everyone else with A chips seems to be doing pretty well, even on air. My friend has the identical setup, ordered the same time and I helped him setup his machine, he idles and loads consistently 10C cooler than me. Just seems odd that our setup is that off. I know there are variables due to ambiet temps. That's the only difference I can see.
Just seeing what the guru's here to say. Any help is appreciated.
Thanks!
http://www.sspmustang.com/OT/x3060/3...os-runlow2.JPG
is 1.35v ish real bad for priming 3600 mhz ?
I just got my 3060, L631B.... I'm excited to try some OCing with it. I finally got the entire system running nice and stable at all stock settings. The thing running a bit 'below' its suggest stock settings is my Memory. Any suggestions on where to start?
4004 thats also prime stable 1.65v i did i suicide run @ 4.15 for fun :) 7638a563 off zzf :)
http://i13.photobucket.com/albums/a299/momomo6789/4.jpg
http://i13.photobucket.com/albums/a2...o6789/pi32.jpg
HI guys,
Soon I'll get one of these, I hope mine will rock as yours :D
see sig
Awesome :eek:Quote:
Originally Posted by Avman
Got a 3060 yeasterday, L631 B115. CPU-Z says 1.113 volts, and no doubt it like low voltages. Temperatures are very high even on 1.4v, below 1.5 seems to be enough for 3.73GHz or more. Great chip, im happy :woot: , now i just need to do something to handle those temps... Lapping and maybe order a Tower 120 (using TR XP-120 now).
I just got mine (same stepping as yours) running along fine at 3.6GHZ with 1.325vcore. But I had to lap the core yesterday before I could get the temps down. I am at 36C idle and 48C load. Before I was at 47C idle and 60C load. Once I started lapping I looked at the IHS and couldn't believe how concave this thing was. Intel sucks for putting these $325 chips out there with such horrible IHS's.Quote:
Originally Posted by ted3
:toast: :toast: :toast: :banana: :banana: :banana:
Hey, question, I was just able to buy one of these Xeon chips for $240 shipped.
Will it work with a ASUS P5N32-E SLI Plus LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail board ?
Or do I need a bios update or is it impossible due to hardware / chipset?
Thanks for the help. I can maybe cancel this order.
I really would like to have this answered asap.
Thanks in advance!
Nice volts. I can run mine below 1.4v at 3.6GHz, but then it will reboot when running TAT at 100% both cores. 1.4125v (1.365v reported by IDU @ full load) is the lowest TAT stable. Prime/Orthos is no problem so maybe i shouldnt care about TAT. Gonna lap it when i get a Bad Axe 2 next week and then see how high it can go.Quote:
Originally Posted by sofarfrome
Hmmm just finished read whole thread a minute ago. but dont see any 3D mark 2006 CPU score, just wondering the score. what is the basic different between conroe with this xeon chip? anyone could explain it?
thanks n best regards :)
They are the same.
OMG, so it's only differ from the name only? there's no advantage using Xeon, in my country Xeon more expensive about US$5-US$10 than conroe 6600.
thanks fhchris for the answer :-)
Xeons are better quality than a normal Conroe E6x00.Quote:
Originally Posted by Firlando
I would pay the extra 10$ and get the xeon :)
so are they all good or are there some duds as well
i want o change my E6600ES B1
I have bought three Xeon 3060s. Each one primed 3900mhz on water.
Two were from newegg. Last from another retailer. All sealed.
FreeCableguy owns my old L629A780 :)
My last Xeon could prime 3600 @ 1.35v easily, with 7+ hours of 3903 walling the board.
IMHO, YOU HAVE A GOOD CHANCE AT GETTING A BETTER X3060 THAN X6800!
Afireinside's L630A Xeon, "handpicked" by newegg ;D
470*9 = 4230 3d01 on WATER?
http://sean.nickfire.com/core2redux/71.5k-3d01.JPG
http://www.xtremesystems.org/forums/...d.php?t=134205
My X6800 could not even pass 1m @ that speed.
Just be carefull what you get, as here are also 763xyyy :eek: Xeons around - so far i have seen 3050 and 3060īs with that FPO/Batch. They do NOT clock that well :( , they stay very cool (stock-idle- ~ 20to25c) but thatīs it. Try to get a L630 or L631 and you are good to go ;) for 3.6GHz between 1.3V and 1.35V. Best L631B115 i had so far could do 3.71.35V, 3.8@1.40V :clap:Quote:
Pete an L630 or L631 B or A? :D I saw an L631B locally should I pick it up? :stick:Quote:
Originally Posted by Pete@X
