That is REALLY nice for just a single disc but, you lose in the access times dept.
2x WD 640GB RAID 0
2x Seagate 320GB RAID 0
http://img206.imageshack.us/img206/6243/asdfwi3.th.jpg
http://img205.imageshack.us/img205/7439/hdtunebz1.jpg
ludicrous access time
Q6600 B3 @ 3.6Ghz
1x Gigabyte i-ram with 64bit xp installed
30% CPU usage wtf
EDIT:
this make more sense
2% CPU
http://img49.imageshack.us/img49/9476/hdtachxl4.jpg
I knew that I-ram was good but, I didn't realize there was ZERO access time.Really nice. I just don't like the limited capacity.
Supposedly the ACard Device was going to be out end of august
ddr2 with up to 8GB dimms
http://www.acard.com/english/newstabpop.jsp?idno=81
I never heard of that one, it is better, twice the capacity of the I-rams. When they get over 10gigs is when they would be more appealing. By that time the Fusions will have gone down in price. I'm kind of commited to the SSD's now. (Invested alot) I figure if I get a good controller card and continue to add SSD's to my RAID0 I'll have SCREAMING throughput.
no, it takes a single 8GB ddr2 stick for a max of 64gb for the 2 sata port model
WD Velociraptor 80GB - AHCI Clean XP SP3 Install
http://www.twilightstars.org/levish/vr80-1gbRam.JPG
Man that has a high burst rate! whats the difference from a regular raptor? I mean other than the higher capacity. Is it the interface? I'm thinking mine has a 1.5gb/sec interface
its a bit higher in sustained and burst and has ncq afaik, SATA 3Gb/s interface on the VR's, I don't own any 150's and 300's but I believe they are a bit faster than my 80GB models
That was the OEM model (that comes in Dells) btw not sure how a desktop version would differ (probably only slightly)
Will have Samsung Spinpoint F1 320's (HD322HJ) and a 60GB OCZ Core V2 shortly
Got a email back from Acard with regards to their drive, its been pushed back to October, really looking forward to that :D
two different Samsung Spinpoint F1 320's
http://www.twilightstars.org/levish/sam320gb.JPG
http://www.twilightstars.org/levish/sam320gb2.JPG
hp 36,4gb scsi drive, dunno the exact model nr. it's a hp bl20p g3 drive :p:
I haven't looked in the thread but I imagine this is a bit unique. 4GB CF 300X connected to a CF to IDE converter. All this PC is used for is surfing the Internet so space is relatively unimportant.
http://img.photobucket.com/albums/v6..._TRANSCEND.png
http://img.photobucket.com/albums/v6...BTranscend.png
Proverbial HDD
http://www.newegg.com/Product/Produc...82E16820208418
Adapter
http://www.newegg.com/Product/Produc...82E16822998003
Reason I went this route is because where the PC is located I was going through a HDD or 2 a year. It's hard on a HDD to not crap out in the Texas heat.
40+MB a sec is excellent for CF cards afaik
OCZ Core V2 - 60GB - AHCI on - XP SP3 - Intel ICH9R
http://www.twilightstars.org/levish/oczcore260gb.JPG
Will be re-doing with AHCI off
http://i31.photobucket.com/albums/c3...Untitled22.png
Western Digital 250GB 16MB Cache in RAID0
Models: WD2500KS + WD2500YS
Not bad for a single WD3200AAKS. :)
http://i70.photobucket.com/albums/i1...200AAKS-02.jpg
2 x 60GB OCZ core V2 ssd's raid 0 adaptec 2405. Just a couple of test runs.
Long test.
Attachment 84464
Short test.
Attachment 84465
Attachment 84482
Man your read/write levels are almost as high as mine and I have three SSD's. This leads me to believe if I got a RAID controller card it would increase my performance. I kind of figured it would but, I wasn't completely
convinced I ought to spend the money on one.
mine's a single WD 5000KS
A pair of WD6400AAKS ' s on SB600...here 54GB Raid-0 Stripe shown (rest 570GB on Raid-1 Stripe)...
http://i256.photobucket.com/albums/h...SB600-WD64.jpg
HD Tune: WDC WD3000GLFS-01F8U Benchmark
Transfer Rate Minimum : 77.1 MB/sec
Transfer Rate Maximum : 122.2 MB/sec
Transfer Rate Average : 102.4 MB/sec
Access Time : 7.2 ms
Burst Rate : 172.6 MB/sec
CPU Usage : 4.3%
Ok, I give up. How do you get the images into a reply in vista 64 Taking a copy doesn't seem to work nor does taking an image from the hdtune intself
http://tweakers.net/ext/f/gaVekUy5Vj...iQ57/thumb.jpg
2x WD Raptor 36GB 10k on NForce 550 board.
I wont get such amazing speeds if my X2 3800+ 2GHz is'nt overclocked to at least 2.6GHz haha.
