Proposed Stable Settings @ 400x9
Here's another stable option to try, more realistic for the CPU you have. try items in "BOLD", All values are actual, as reported.
Originally Posted by
TAOTAO161
I dont now from where to start i reach FSB 395*9 easy, but when i change to FSB 400 the all game are change, i raise and raise my CPU/PLL/NB/FSB voltage the system is not come to stability.
the CPU Configuration can change anything ?
here is my config
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Setting : 9
FSB Frequency : 400
FSB Strap to North Bridge : AUTO will use best stable strap if 2 are availablePCI-E Frequency: 100
DRAM Frequency: AUTO will use 1:1 for stability
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
DRAM Static Read Control: Enabled play w/ AUTO to see any changes, 400FSB is usually low enough to not really see a big difference here
Ai Clock Twister : LIGHT
Transaction Booster : DISABLED
relax level 0
CPU Voltage : 1.5370v (BIOS)
CPU PLL Voltage : 1.632v
North Bridge Voltage : 1.55v cause of x2 GPU, & quad, may need up to 1.58v
DRAM Voltage : 2.1v just for stability, less as can be later
FSB Termination Voltage : 1.488v
South Bridge Voltage : 1.104v
CPU GTL Reference : 63x
North Bridge GTL Reference : 67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : 1.56~1.60v
Under Advanced
And CPU Configuration:
C1E Suppport : Disabled - I'd enable this if it is stable later
CPU TM Function : Enabled
Vanderpool Technology : Disabled - try w/ this disabled for now
Execute Disable Bit : Disabled try it like this for now, enable as stable laterMax CPUID Value Limit : Disabled
Let me know if this helps. This is for basic stable 1:1 @ 400x9. A very and practically stock today on this mobo.
EDIT: if not using any legacy USB, try disabling this in BIOS and see if it gets past 2nd pass. My iPod locked up once and hung there too. Just a thought. See "Sources" note above to confirm what I just mentioned earlier on about SB and PCIE.
