nice looking BeeN
nice looking BeeN
[QUOTE=bundymania;2303342]...a bunch of new pics out of my "laboratory" ;)
http://www.abload.de/img/inside1wj.jpg
What are you using to get the red color in your water? I'm using red food coloring for mine but I'm not sure if its a good idea.
Budy is using Food Color too :cool:
I dont see how food coloring could/would hurt flow...maybe I am wrong...*-)
My Giant watercooler AM2 :D
Big...Big...Big
DarkWing6611: I hope you have some killer pump for that block...lol
omg thats huge, post some temps.
btw, what are you using for VRMs, NB+SB? i have same board, so im asking ;)
i think this is not a good design cause with the very wide area for water to run in and the very small opening i guess most of the water will run @ the middle of the block while the rest @ the sides will be much slower
While it looks very well made, I think the pins are just too thick to properly dissipate the heat quickly enough.
Here is some of my p180. This is what I had to work with. I have replaced the noctuas with YL's and I just ordered a MCR320 to replace the two radiators.
http://www.turborocco.com/watercooledp180.jpg
http://www.turborocco.com/watercooledp1802.jpg
Nice and clean.
Make sure you fill up that Swiftech Micro-Res to the brim though.
Look at what the delivery guy brought me today! :D
http://img165.imageshack.us/img165/1...0001yk4.th.jpg
http://img258.imageshack.us/img258/1...0005tx4.th.jpg
http://img19.imageshack.us/img19/351...0006to8.th.jpg
Stuff in pics:
2x Sound dampening material
1x Logisys dual 12" UV Cold cathodes
1x A.C. Ryan Twinoverboost dual 12" UV Cold cathodes
4x Yates Medium speed (For push pull config with my current Scythes!)
1x Techflex Sleeving kit + some 1\4" Sleeving and 3\8" Heatshrink
1x OCZ XTC Ram cooler
1x EK Multioption reservoir 150
4x Cold cathodes extensions
6x EK barbs
2x DD Hi Flow barbs
10x Blue leds
30+ Zip-ties
1x DD Black Fill-Port
4x Rubber feet
1x Thermalright Back plate for my Fuzion
1x MCW30
1x EK 8800GTX Full-cover WB (Damn thats one sexy block!)
10" Tygon 1/2" ID 3/4" OD Tubing
20" Masterkleer 7/16" ID 5/8" OD Tubing (Just for the heck of it...lol)
1x Coolsleeves 625 UV Blue
1x Coolsleeves 625 Clear
1x Coolsleeves 625 UV Green
1x PT_Nuke
1x D-Tek Fire Red Dye
1x D-Tek Alien Green Dye
1x D-Tek Visible Blue Dye
1x D-Tek Orange\Yellow Dye
1x Swiftech's Hydrx
2x G11 Pentosin and one half UV bottle
1x Half Zerex bottle
Oh and the P5W DH Deluxe is just there because my good friend, cadaveca, fixed it for me and i got it back today! Thanks a tone m8! :D
This stuff above + what i currently have (See specs in sig) will do a freaking nice build in my U2-UFO :D
Got enough colours of dies? :)
Well, check this out. Take, let's say, about 1 Gal of distilled water, pour some of all the dyes + some G11\Zerex + some PT_Nuke you see in the pics above and you get a freaking UV Brown coolant flowing in your tubing! Now thats Xtreme! ROFL! :rofl:
Nah but seriously, i want to make sure i had the choice of color when i would have made my choice :) You know just in case...
Still, is nothing compared to Mr. H20 that, a few months ago, got some Xtra C2Ds mobos just in case...LOL Anybody know what the heck im talking about ? :D
well, the 320 should keep it fine... at least i think ;)
That's right Madam the 320 will cool both no problem. Trike where u puttin the triple?
I Decided not to cool the gpu with this setup as the radiators are already heatsoaking. My idle temps right now are pretty bad. 36C. Vcore is set at 1.5 i'm only at 3.3 stable right now. This is on a lapped Xeon 3060. Kinda dissapointed with the results. I can run 3.6 no problem and orthos no problem, but once I start rendering some video, the video ends up with artifacts. took me a while to figure out it was the overclock. I was hoping i could hit 3.8, but seems unlikely.
Now i'm going to mount the MCR320 on the back with a rad box. Figured this would be the best bang for the buck upgrade. more surface area and reduce the pressure drop by getting rid of the two radiators.
I'm still debating if i want to cool the 1950xt. I don't know if i'm going to upgrade the vid card soon. I guess the MCW60 is fairly compatible with both nvidia and ati.
With the GPU added into the loop, how much higher will the temps be? Would I get better results if i just left the gpu out?
I'm not really overclocking the vidcard right now, but there's still alot of heat coming off of the hs/fan.
@Patriote: ohh damn :eek: wht ur going to do ? cool ur House with all that :rolleyes: 30feet tubings FTW !!!
Patriote you gonna stack 4 cubes together and watercool em....
or should i think that you're gonna cram your ufo to the limit...
There isn't that much stuff guys :D But yeah ima "cram" my UFO! LOL
Nice setup Redstars :D
wht r the Comp n WC specs ?
