[QUOTE=joshuaboston;2645031]Thanks guys !!!
im now on 3.6Ghz at bios setting 1.45V ! ram at 1000Mhz at 2.2V 4-4-4-12
but i saw the voltage reading in uGURU for CPU volt is 1.40v - 1.42V ???
by the way, im not at bios14... should i go to beta 16 ?
[QUOTE=cscheat;2646579]There is a problem with the Abit Pro P35... it has to do with the CPU voltage drop. From what I understand it is a "hardware problem" the newest bios has helped a little but there will always be a Voltage drop for your CPU... but that should not really matter.. as long as you are on your lowest possible settings (stability presummed). But in bios 14 there was a "very" large voltage fluctuation with my CPU Vcore... and the beta bios has helped that problem.. ALOT!!
I have the beta bios 16.03... REALLY HELPED OUT ALOT!!! I think I may wait a little longer before I go to 16.04... but if you are on 14... DEFINATELY upgrade to the highest beta bios... I am sure it will allow you to lower a few settings and should add more mobo stability.
Other thoughts... I had to wait about 200 hours before my thermal compound cured... thats running time. I used Artic Cooling MX-2.
The only thing I kind of don't understand is why I am able to set my Vcore under 1.4V and still pass prime 1024 at 3.6Ghz, but maybe I just have not looked at what other people are doing. Mind you I seriously spent days trying to figure out the best settings in each catagory.
Have you tried to tighten your memory timming? The last time I ran Prime 1024 I did it at 406 seconds. Whats your score? At whats your temps using "coretemp" mine is 38-40 at ideal and in the high 60's under load.
I agree, I have been keeping an eye on this forum... very greatful for it.
Vdroop is part of the Intel specification so if you want Intel accreditation you will have Vdroop at defaults (some mobos get around this by having a secondary circuit that can get enabled from BIOS - in their default states though they are disabled to comply with Intel).
As such the IP35 Pro is complying with Intel design specs.
Hi Guys,
Just got my system built...but am having a hard time trying to figure out how to do the following:
CONFIG: (3) 320GB Hard Drives SATA
GOAL: Setup a RAID 1 config with WinXP Pro SP2 using 2 of the drives. 3rd drive will be for non-critical data (stand-alone).
PROBLEMS:
1. I have no floppy drive. Even if I did, all the drivers are on the CDROM included with the mobo so installing the RAID controller drivers during setup is not doable.
2. In order to get WinXP installed can I set the BIOS SATA controller in IDE mode to get WinXP installed on one of the drives and then change it to RAID mode afterwards without destroying my data on the install drive?
3. Or should I use Intel Matrix Storage Manager to setup the RAID?
4. If none of the above will work how do I get the drivers to install during WinXP setup? I know I can press F6 to install drivers, but I don't have them on a floppy as I stated.
A simple step-by-step on how to install WinXP Pro without the Intel RAID drivers would be GREATLY appreciated!!! Thanks!!!
:) Thanks for any help!
-scaryogre
How does this mobo do under extreme cooling?
Ive heard great things about this board just curious before I purchase one.
What do you call extreme cooling?
Just wondered... :) The question is ask often and usually by people that have no concept or ability to do Dice or LN2... :rolleyes:
I can't answer the question as I do H2O because I need a 24/7 machine and don't waste time with bragging rights or extreme benchies that mean nothing relating to everyday performance...
Regards-
PS: Yet this is "xtemesystems" so whatever... ;)
Im sure I can find out easily with a few searches (which I will) but any idea how well documented the voltmod guides are for this board?
Yeah, thanks...That was pretty much a worthless post. Assuming I want to save $6 wasn't (and isn't) the issue. I don't have space for it in my chassis.
In an attempt to actually help others I figured it out with the assistance of the below link and am posting in case it helps someone else in the same situation.
http://www.msfn.org/board/Integratio...s-t107504.html
-scaryogre
That's cool, no problem... As far as being a worthless post, it was a worthless question to start with, but whatever... Heck with where you have room, just hook it up outside of the case to do your install, then put it in the closet until you need it again... :) But whatever works for you... ;)
Every once in a while when I reboot or cold boot , I get a double beep. It's one weird toned beep then the normal post beep. It happens very sporadically and I cannot figure out what it is. I check uGuru and everything checks out fine.
Also, yesterday I rebooted out of Ubuntu and I heard about 5-6 short beeps and the comp froze. I don't know if t was an Ubuntu error that caused it or something serious. Hasn't happened again.
Is there some sort of beep history log in the bios? If not, what is the best way to figure out the problem. :shrug:
D'oh......I just re-read my post...I meant the xtra beep is a little longer than the post beep lol.
