Good find, out he goes.
With the SATA 6G Marvell controller recently going TANGO UNIFORM on my R3E, I desperately wanted to RMA this poor 'ole boy. I was afraid because I had heard that sometimes dealing with ASUS could be a nightmare. :eek:
Thankfully, when I bought my R3E board, I got the VIP membership. I guess the perks of buying $400 motherboard. :D
I should have the new board cross-shipped from Fremont, CA real soon. I was told by the wide-eyed gent, Mark, that the new boards have a far better Marvell controller onboard. I do hope so ... I don't like being without for very long ... :p:
:up: to ASUS though, very nice guy, that Mark. And the process so far has not been what I imagined it to be. Whoo! ;)
Oh, you get better RMA service on ROG boards?
Too bad that mine wont break lol.
Not using sidebar either, don't like it. Just run AIDA64 and use OSD. ;)
No proble, you're welcome. Looking forward to your second run. :up:
Yeah, I know, but it's still about 3/4 of my monthly paycheck. Low standard here. :(
:welcome:
You mean QPI LLC, right? It is load line calibration for VTT (QPI/DRAM) voltage and you should enable it, cause it sets voltage just right as you set in BIOS, no vdroop.
yes sorry , i meant QPI_LLC jumper on the mainboard as shown in this pic ....
http://www.pctunerup.com/up/results/...837_resize.JPG
wasn't that allready on intel mainboards? :rolleyes:
ok that's nice to know , i'll enable the jumper :up:
and .... what are those two " EZ Plugs " on the mainboard ? should i connect power to theme? the same thing for those two 8 pins cpu power, wich should i connect? .... the user guide says that one is V1 and V2 for the second, i guess should i connet the V2 only, right? ...
i'm sorry for all this questions, but i need to know all about, is my first intel mainboard ;)
ok.... thank you very much for the advice ;) i'll try by connecting the two 8 pins and try as you did, 8 + 4 .... ehehhe ... ;)
Has anyone noticed that their CPU tempertures are not showing up in CPU-Z hardware (V1.17.0 Driver version 135)? Mine did at one time. AThe temp sensors must be fine because all cores show up in Real Temp GT 3.60
Finally made it LinX stable - 5.0022GHz :D
Submission is in :up:
can someone tell me what BIOS is for Bloomfield the best?
I downloaded the latest hwmonitor free and it seems to show 6 cores. Some of the voltages seem to be mislabeled though. No Idea what it thinks CPU PLL is, but IOH PCIE +1.5V is probably CPU PLL.
http://i144.photobucket.com/albums/r.../hwmon-r3e.jpg
I've never had something read my GTX275 VIN's before, I wonder why they're running at different voltages. Both are EVGA GTX275 Superclocked, and they don't throttle down either(I use evga precision to force them to full speed all the time).
OPT1 temp: Ambient
OPT2 temp: Coolant
OPT3 temp: Exhaust
why on windows cpu-z says that (i'm at default speed) i've got 22.000v on cpu? O_o
http://www.pctunerup.com/up/results/...14326_cazz.JPG
Hi all my new R3X just arrived and i have some very first questions.
1.About the fan controlling , i noticed that all FAN headers are 4pin, my HAF-X's fans and my NH-D14's fans are all 3 pin , so how can i let the motherboard automatically adjust the fan speed according to temps (Q-FAN) ????
Is there a way through bios to change the way the mobo controls the fans (instead of PWM to switch to classic 3pin control process?)
Otherwise the only way is a fan controller or maybe adapters 4pinPWM to 3pin?
2. I also would like to know which bios is the best for i7 OC. I always download the latest official version but if your experience is different ..be my guest :)
