I tried Maximus IV Gene-Z and on basic untweaked settings it was even slightly faster than MVG, but i heard max multi is limited to x59 on Z68.
I heard x59 is max multi on Z68 as well. :yepp:
@l0ud_sil3nc3: Good start with IB! :up:
Well that's a shame.
I may as well just get a cheap P67/Z68 board then for Sandy. (Will be my 24/7 gaming machine, selling AMD faildozer)
A guy near me clued me in on a local store with a lot of used 1366/1155 motherboards for cheap, and I found a 57x 2600K.
Should be enough CPU power for low end HD4850 and HD5770s.
Someone knock Arisitidis down a few points quick!! :D
Wow!! :up: :up: :up:
http://img819.imageshack.us/img819/3...ay12th2012.jpg
This is awesome!
Aristidis just dropped a few Ivy bombs on your parade but it's still awesome :up:
Don_Dan here is some of that 8-10-7 magic you requested:D
http://i.imgur.com/Q5ZtZ.jpg
and I just realized I forgot the SPD tab:doh:
Nice chip :up:
I'm pending to buy 57x 2600K, seems I'm always a generation or a few months behind...but it will be my 24/7 chip too.
Will attempt to try Ivy this summer, but I need to buy a dewar first and they are really hard to find for cheap.
I hope my STT Hyper work with it, they do 2133 7-7-6-19 32M at 1.77v on AMD Bulldozer.
Going to grab a M4E/Z to clock those hypers?
if they are good they should work fine, I know both my STT kits did not work with SB as they were not good enough (2000 7-7-7-21 & 2200 8-8-8-24) and would not run the 2133 divider, however I have a set of decent 2000 7-8-7-20 Dominator GT's and they run flawlessly with P67/Z68 but I have not tested them on Z77, too slow:p
I don't think I have enough money for M4E/Z, I might have to go with a cheaper board. I have a mid tower case too, not sure if E-ATX fits(?)
My 3x2GB STT 2000 7-7-7-21 absolutely smashed my 2200 8-8-8-24 which I actually traded with ZenEffect (Sorry ZenEffect :p:) for PSC that ended up 2500 7-11-7-24 on faildozer, but he could just barely get the Hyper kit to do 2133 8-8-8-24 on SB. My PSC should do 6-10-6-24 past 2200 with SB though, so I need to see which is best (if Hypers work).
None of my Hypers out of the 10GB I've had have scaled with tRCD = CAS +1, and I can run tRP = CAS -1 at almost the same frequency. 7-8-7 MHz = 7-7-6 MHz...
Just bought 57x 2600K and MIVE :)
Show some results when you get your new parts! :up:
Not much activity lately.
We're losing team points!
wooohooo Warzian!
You finally posted in the thread.:welcome:
