Pioneer Problem Update and New Sata Question
I updated the Pioneer firmware from 1-23 to the latest 1-29 version. This helped in reducing the number of bad sections from about 14 to only 2. Interesting that when I reburned the same project immediately after the prevous burn there were still 2 bad sections, but in different locations though. Is there something else I can do to get complete good burns?
My external sata conection does not appear to be functional. The sata port Raid 1 (upper left on mb next to rear panel connectors) works fine. Both are on the JMicron controller and it is enabled and set to Basic in the bios. Should not both be working with this setting? Is there something else I have to do.
Please help me on these items. So much to learn and not all explained easily in the manual.
Thank you guys for the other helpyou have already provided.
Deep prob. supply at 12volts until winbloze then its 9.12 volts
problem.. with this Antec 500 supply in the bios it says the 12 volt rail is a little over 12 volts but after finishing booting looking at sandra, mbm & Everest they all say the voltage is 9.18 sometimes drops to 9.02 that seems almost impossible since im running this E6600 duo cpu at 3.4ghz 1:1 . stable completelty running for a week now.
So i tried figuring it out intelligently. What would create such a load after booting into winboze pro that it would drop the voltage 3 volts - bingo i thought USB so i unplugged everything from my my computer nothing plugged in still the bios said 12volts = 12 volts but in winbloze all utils i ran states 9.18 volts. what the hey? And the thing is solid asa rock at 3.4ghz its a 2.4 ghz cpu temp 41 C according to mbm with 2 update.. i even unplugged the internal floppy
Any ideas? this doesnt make sense. of course this may not be a power supply problem but if the system was being loaded down to the point the voltage drops that much then there would be something sucking more current then the supply can handle (ohms law )
i'm a loss 4 words other then trying another supply damn thats a lot of work 4 someone dan near blind and physically messed up..
System: mobo Asus P5W dh dlx,
1 - Core Duo 2.4 ghz E6600 (currently running at 3.4 ghz rock solid)
2 gigs ram
2- 500 gig segate Drives SATAII on a Sil EZ_backup mobo ports
2 - 36 Gig SATA 1 Raptors on INCH7R - Raid0 Array
2 - DVD Writers on the pcie Sil card
1- DVD Writer plextor 760A IDE
1 - Sil pcie SATA II Card (2 internal sata ports used 4 the above SATA DVD writers)
2 - 4 port usb self powered hubs, web cam logitec fusion, 2 - 150 DVD/CD carosels (self powered) USB 2.0
guess ill now run a benchmark and see where ts at with this supposedly 9.18 volts on the 12 volt line
Suggestions anyone? i know there some og's out there like myself... or young hot shots arent they?
Any info is appreciated...
gone 2 research.. Thank u
Pioneer problem fixed, still need help on sata
Found what was causing Pioneer DVD not working properly. Bad cable, even though it was brand new. Replaced cable and all working fine now.
Still have not found solution for sata question: My external sata conection does not appear to be functional. The sata port Raid 1 (upper left on mb next to rear panel connectors) works fine. Sata port Raid 1 shows drive in Explorer, but nothing shows up for the rear outlet esata port. Both are on the JMicron controller and it is enabled and set to Basic in the bios. Should not both be working with this setting? Is there something else I have to do.
Also, how do you remove the sata drive as hot swap. A USB shows an icon in the tray and when you click on it it asks which USB item you want to close. I don't see anything anywhere for closing down a sata drive. Do you do tis through Device Manager and use the disable function? Not the uninstall, right?
Any help please. Thank you.
lawrywild: why do you currently recommend BIOS 1602?
You've recently changed your recommended BIOS 1901 into version 1602.
Please explain why.
