Yap, thats the noctua NH-C12P.
Replace the P12 with a Minebea Mid. :D
Must import from newegg! LOL.
@ragnarok: shouldn't the heatpipes of the NH-C12P be facing to the rear?
Cause i want the cooler to cool the mobo mosfet cooler below. :)
you will love the 9800GTX+ I thinks it is better than the GTX 260
A 260GTX is actually better than a 9800GTX+. :)
maybe i will go siao again and change to 260GTX.
Hey i change from a HD3870 to 8800GTS 512MB to 9800GTX+ in less than a week! Haha
I have :p:
http://www.staticice.com.au/cgi-bin/....cgi?q=mushkin
But very few kits and stores.
Dude that's some value DDR2 and SODIMM which no one cares about here LOL. It's probably not even Mushkin DDR2 and just Gamedude being Gamedude [crap]
I put a pulse in my new beast today and initial results are looking very good:
http://i377.photobucket.com/albums/o...5Trunning1.jpg
Yeah Brisbane is way to dusty dude, even with a case but I think Santa should get you an air compressor this December :D
oh gosh eagle you gotta clean your zalman!!
its so dusty!
btw y do u need fans for ur RAM
as far as i know, RAM isnt hot at all
Rule of thumb : 2V and over = fan on ram.
Well Im testing the OC potential of the RAM at the moment and I think the cooler will help, I took the DDR MHz from (stock) 666-776 to generate some baseline data:
http://i4memory.com/f83/gskill-2x1g-...-oc-run-10731/
With the new card...
http://img.photobucket.com/albums/v4...5/P1040275.jpg
Yet to tidy up the cables...
ragnarok95, You should put those rams in to dual channel..
i don't think they would fit lol
ragnarok95: If you turn the cpu heatsink 180 degrees then would it be possible to use the other ram slots?
They should if he turns the cpu heatsink around.
My case has a dust filter as well. It still gets really dusty
I just go without dust filters. I like the extra airflow and the dust can be dealt with by my air compressor.
