The 2600K is even cheaper than the FX in Sweden, but I guess those prices will change the next weeks.
Your USD prices are including 25 % Norwegian tax, right?
In Sweden:
http://www.prisjakt.nu/produkt.php?j...,995743,995734
In Sweden:
All USD prices are including 25% Norwegian tax :up:
FX 8120: 1630,- NOK = 281$
FX 6100: 1384,- NOK = 238$
Attachment 121045
If i recall correctly, server version was scheduled to h2 for long time now and i think there was info about it bd shipping to cray in summer. With Cray I think they needed hw not necessarily latest most performing version of bios & os scheduler guides. It might be that AMD delivered almost on time to them by using all they could get from 32nm process if those bad yield rumours are true. If B2F is latest version and it was B2 already before summer, it means they did not make any big modifications, only optimisations to get better yield ect. Ofc, we may never know.
absolutely pi has to stay in it... good indication of ram/bandwith scaling, wprime clearly shows the cores working...
^^^ was that quote from chew* on another thread?
^This
Here is the link to it --> http://www.xtremesystems.org/forums/...60#post4952360
Erm, seeing specs for server chippery, one could note that BD came with more cores, higher clocks at same or lower TDP. It is a no brainer as it is drop in compatible. You don't have to change everything, but just upgrade bios and pop BD in. There's also support for DDR3 1600 Mhz on server side, i'm sure that will come handy too.
Surely you don't think it is as scummy as paying off Dell etc to not use AMD chips, slow other chips in their compilers etc. Or for that matter, willy nilly deciding which ISA is supported or not (remember SSE5, FMA4). If you talk about X86 compatibility, then Intel has a lot more to answer than other two companies involved.
Also, wait till NDA lapses before you decry the chip. As it is, we all know how Nvidia screwed DX10. We also have recently learned that windows is more optimized for HT than actual cores, which is to be fixed. So either you could be sane, and rational, or just jump around tearing up your hair.
And here's some stuff-
http://semiaccurate.com/2011/10/10/e...-architecture/
Savantu is one of the resident AMD haters (and was banned from the news section for trolling the AMD threads I believe), so I do recommend taking anything he says regarding AMD with a fairly large amount of salt ;)
I am just waiting around now, coming back to the same threads every half an hour or so, expecting some good news.....nothing yet..
anyione up to date on this ? My win7 and 8 were fully patched, no idea if this is included yes or no
"Actually, we already have such an issue known for Bulldozer, and NO bench-marked system has the patch installed!
The shared L1 cache is causing cross invalidations across threads so that the prefetch data is incorrect in too many cases and data must be fetched again. The fix is a "simple" memory alignment and (possible)tagging system in the kernel of Windows/Linux.
I reviewed the code for the Linux patch and was astonished by just how little I know of the Linux kernel... lol! In any event, it could easily cost 10% in terms of single threaded performance, possibly more than double that in multi-threaded loads on the same module due to the increased contention and randomness of accesses.
Not sure if ordained reviewers have been given access to the MS patch, but I'd imagine (and hope) so! Last I saw, the Linux kernel patch was still being worked on by AMD (publicly) and Linus was showing some distaste for the method used to address the issue""
And Tiborr, sorry but changing all sort of options in the bios is not done by most users, neither is setting affinity or co.. Either it works or it doesn't. Not everybody has Chews knowledge on the matter. Disabling PowerManageralready boosted multithreaded performance on my testbed...
@ Leeghoofd: Where is this text from? Is it recently posted/mailed somewhere or quite long ago?
Talking to Maki in a moment, keep you lot updated ( if I am allowed )
