I have 4x1GB of ballitix Tracer and I have them set at a 1:1.2 at 5-4-4-11, but I am overclocking my CPU to 3.6Ghz. Best way to find out how to overclock is to google a overclocking guide or go back 20 pages and start reading.
Good LUCK.
this board doesn't seem to like the cl4 thing with 4 gigs of memory and aquad ... the highest I have had my tracers at 4-4-4-12 is 1030 on the 1:1.25 divider. I can't seem to get any higher. I can go as far as 1150 with 5-4-4 with much better performance, so I gave up on the cl4 dreams I had.
PM sent inge
i think the DFI bios on the X38 and P35 is far more complicated than it has to be...it would be fine if you are computer science major BUT for most of us normal users, it is quite the thing to figure it out...it makes the Pro bios look like child's play!;)
AND..for a mature Pro bios compared to DFI's first bios is about the same place in getting a good overclock...the Pro bios on the early release allowed me to easily get to 3.8 ghz while i had to work hard at getting the DFI bios to cooperate...probably due to the complication and numerous settings there to manipulate in DFI's bios.
Abit IP35 Pro named: "Motherboard of the Year"
http://www.overclockersclub.com/guid...rds_2007/7.htm
can I use the 16.b04 bios on my ip35-e?
I managed to get a floppy drive and trying the beta bios now.
Does anyone have issues with bios 16 beta 4?
1. The cpu reading in uGuru is way off. Just starting up the computer, it shows 52C.
2. I specifically set the voltage for RAM as 2.175V in the bios but uGuru shows 2.2V.
Also I tried same settings I had under bios 14 on this new bios and it failed in prime95 in 3 minutes.
agreed, coretem shows the cores at about 38 to 40 yet everest reports cputemp at 55?!?!
Ok Got a different kind of question. I've got 4 identical 320GB drives in the lower hdd area. I'm taking my front rad out so I'm moving the two RAIDed drives to the middle hdd bay, well my question is is there a way to tell which drives are RAIDED? I have the 1st two in the RAID menu selected.
-edit
Also people who have attached fans to their PWMs can you post pictures?
Hey there!
I have Q6600 B3 version. Does anyone have here B3 that is OC to 3,8-3,9Ghz with aircooling? I have TRUE 120 cooler myself, and have stable 3,6GHz OC. But can't get it stable past 3,8 Ghz. Can someone share their bios voltage configuration? I'll post mine later, when i get home. Thanx, and greets from Estonia.
Got my system running for about a week now. On and off just playing games and running 3DMark etc
Had a go at overclocking my Q6600 (G0) with the stock intel cooler (should setup my WC this weekend) pushed it to 2.9GHz with 30Min OCCT stable Highest Coretemp reading was 59DegC under load. I was moving up in 10MHz increments so it took a while to get to 2.9GHz I'm just watching the temps trying to stay under 65 with the CPU cooler.
Has anyone had problems with uguru causing crashes in Vista64? I'm pretty sure I have the latest version but any comments? When I close uguru I dont get any freezes!?!
Cheers,
emu
so any1 know how to determine which HDD's are physically part of the RAID?
Thanks Ace. I knew this would be the place to confirm my suspicions!:cool:
So you cant set voltages etc with uguru in Vista64bit? I wqondered why that didnt seem to work. I might try my other boot with XP havent tried it for a week! it defaults to Vista! :shrug: 0
Whats the max temp you would go with the stock cooler? is 60DegC pushing it? I read somewhere that they are specced to about 65DegC but i'm interested in an experienced answer.
@silverphoenix: Sorry mate cant help besides disconnecting the drives to work out which is which! and I'm not sure that is the best way!
Cheers,
emu
i tried vista 64 but it was RC2 and there were issues..i read a few complaining about Uguru in vista 64...my recommendation is to set it to run under XP compatibility...don't ask how to, i just don't remember!;)
Firstly if I leave it running while stress testing I get a fatal freeze! I'm sure I have the latest version but will check. Maybe I'll change the exe to run in XP compatability mode.
Where do you change the voltages? do you go into the settings etc? Not sure I am in the right spot to start with really!
I'll try it out when I get home and let u know.
not sure how many HDD's are connected in your system in a RAID, but after post, in the intel screen it will show the disk, and will show if its a member or not. I mark all my drives with a marker on top to help out in things like this, or if Iam swapping out drives so i know whats on them.
check the screen after post, or just unplug them also, thats the sure way to know.
