3 Ghz with 1.42v on air is what all the 0608MPMWs are doing. It is the most consistent stepping i have seen. Mine did 3 Ghz with 1.40v, but that's only because i'm on watercooling, on air i'm sure it would have performed just like the others. You guys need to push that stepping, i shouldn't be the only one with a prime screenshot at 3.1!
Repoman i think the CCB1Es burn in a lot, also very temperature sensitive. Get temps down as much as you can and you will be rewarded.
