OMF 30seg with 2T@2.8ghz
Nice job!
Nice job!
Please I need help. I have two AMD chips one is Opteron 144 cab2e 0545 cpaw.
And the other one is Athlon 64 4000+ Sand Diego cabge 0514 bpmw.
I have no Idea which one to keep as I intend to sell one of them, but not sure which one,
Thx
That is a good SuperPi time with 2T timing? Also that passed OCCT as well:D
148 CACJE 0546 (right out of the box)... http://valid.x86-secret.com/show_oc?id=59144
Well which overclocks better? Um...from either of the two if I was to buy without knowing I would get the Opteron. So my opinion is keep the Opteron.Quote:
Originally Posted by killer_pav
SS: :confused: Where's the 32m ss?:)Quote:
Originally Posted by eemain
Originally Posted by m3ta1head
Originally Posted by TEDY
It all depends on how fast the fan is running and what TIM you are using surely (assuming you got a good seating when you mounted it!).Quote:
I have the fan on a constant 2000rpm with AS5, and with 1.45V it idles at about 35 to 38 depending on room temp. Load goes up into the lower 50's. My case cooling is pretty crappy as well (single 120mm exhaust @ 5V, and PSU 80mm) because I like my rig quiet :)
Suman
this is so strange. the opty 150 i have overclocks EXACTLY the same in my board as the prior SD 3700+ I had. It must be my board (needs high voltage (the same voltage) and same max clockage).
Anyone ever heard of this on dfi nf4?
Maybe I should disconnect 1 or 2 of the power connectors, ha.
man i dont want to board swap due to water cooling cramping things up, etc. what a hassle that will be...
Order water cooling stuff. Hopefully will have it soon. Can't wait to under go higher clocks.
Anyone buy an opty 144 recently off Mwave? What stepping did you get?
in europe the last stepping are :
CAB2E 0545 MPMW
CACJE 0546 APBW
the second are verry bad, impossible to stabilize over 2.5Ghz with more than 1.7v stock cooling, but i've tested only one piece :slap:
i have already one good 144 :banana:
Originally Posted by dogsx2
32M Super Pi? Why? It runs that but isn`t PrimE or OCCT stable ... Now running 2.86Ghz(31*-44*) Prime(3hrs) and OCCT stable at 1.36v(MBM5). Will post screenies when final at 3g+:D
Also need to stretch out this Gskill 2x1g kit... man I love X-Mas;)
pi_rec.txt
- Not calculated. [ 16K]
- Not calculated. [ 32K]
- Not calculated. [ 64K]
- Not calculated. [ 128K]
- Not calculated. [ 256K]
- Not calculated. [ 512K]
+ 000h 00m 30s [ 1M]
+ 000h 01m 09s [ 2M]
- Not calculated. [ 4M]
- Not calculated. [ 8M]
- Not calculated. [ 16M]
+ 000h 26m 42s [ 32M]
Here are my screens so far. This is the CABYE 0535 XPMW I still have from my friend. I know the time is slow but I'm running a pretty low divider just to get this proc figured out before I really start tweaking it. Can anyone post some A64 tweaker screens off some similar UTT like this geil, I seem to have problems with this ram and I dunno if its me or what but it has always seems REALLY finicky, I am used to tccd. Thanks, Happy Holidays!
http://surrealtextures.com/screenie3.jpg
http://surrealtextures.com/screenie4.jpg
http://img484.imageshack.us/img484/5769/ssmedium6mt.jpg
This is why I put no faith in Super Pi... after reboot to tighten mem settings here is what happens!
cajce 0546 BPMW not real good for oc'ing, but would be a good chip for running 24/7. It would do a 32m @ 1.456 at 2972mhz, and a 3005mhz 32m @ 1.55v. Anything more was a no go even with more v. up to 1.66 true. BUT, it had a 57 Tcase and the temp stayed about 11 to 13c on my board. That is about 6c to 8c lower than the other ones which were 63 and 65 Tcasemax chips.
Unfortunet.Quote:
Originally Posted by coop
I just received 1 148 CACJE 0546 and it OC's to 2.915 265x11 on default stock voltage. 3.0 on just 1.45v. I had mine up to almost 3.2 on 1.55v (290x11) but my RAM took a turn for the worse and now gives errors at almost any speed. Ran stable for me up to 3.135 SuperPi 32M and Multiple 3DMARK05 and 01, when running RAM on 133 divider
http://http://img475.imageshack.us/i...lash1626dn.jpg
http://img475.imageshack.us/img475/1494/299show8oq.jpg
in a sn95g5 V2 shuttle barebone on air cooling :)
its for sale for about 222 us$, 187 Eur, 1400Dkr so flexq.87 [at] gmail.com if you are interested. :)
Prime stable 5 hours+ at 3ghz.
http://img512.imageshack.us/img512/3...melarge7tp.png
see my sig :toast:Quote:
Originally Posted by Primoz78
Originally Posted by gundamit
Looks good. How long did it take to clear the dust off of it after sitting so long? You have so many good ones you have to let some of the really good ones sit.:D
TIM?Quote:
Originally Posted by sumang007
I do have a really good CAYBE 0528GPMW sitting. I should problably sell/trade some of the ones that are sitting for a dual core. This latest one however I just got from MWave at the start of last week. I saw so many good results I gave into desire yet again. :DQuote:
I'm gonna buy me a opteron 146. What are the best steppings. I know CABYE 0540 FPMW is very good. Are there any other?
Now I have noticed some of you guys using alittle more voltage on the LDT and Chipset...is this needed for stability. I have always left them alone when overclocking my San Diego chip.
Because I cannot Prime at 3.0GHz for nothing. OCCT passes but Prime fails in ~5-10 seconds.
finally....3006 MHz ;):
http://members.cox.net/mucker/GSkill/FPMW3G1.jpg
http://members.cox.net/mucker/GSkill/FPMW3G2.jpg
http://members.cox.net/mucker/GSkill/FPMWOCCT3G.jpg
146 CABYE 0540 FPMW
XP-90 with AS5
m :)
