Any news on how this bios affects things?
Has anyone done any mods to the NB cooler to improve air cooling? Was thinking of doing a ghetto mod with an old P4 Cpu cooler, just want to get some ideas before I start.
No chance to try yet. Got home from the beach, and was playing with c7 settings on the ram. Was going to flash Monday afternoon, but a bunch of stuff came up. I am going to disassemble to system to mod the case, but will have it on the bench. I hope to do that tomorrow before I work all weekend. If I don't get to it this week, will for sure next week. I put the swiftech nb block that bolts into the stock heatsink. So not air cooled on that. I can't remember if I ever took off the stock sinks to check the thermal paste. I've heard the factory job can suck. I should double check that while I have it out on the bench! Anyone else had luck with the new bios?
Just spent all day putting in an oven/over oven microwave today. Hope to get the system on the bench tomorrow. If not, next Tues.
SETUP
CPU: Intel Core i7-950
Mainboard: ASUS Rampage II EX B3
RAM: CORSAIR DDR3 4G PC3-16000 CL8 DOMINATOR GT
VGA: ATI Radeon HD 5850 1GB
HDD: WD 1500G
Power: Cooler Master SiLENT PRO Gold 1200W
Cooler: THERMOLAB BARAM 2010
Case: CoolerMaster CL-001-KKN1-GP
OS: Microsoft Windows 7 64Bit
http://cfile27.uf.tistory.com/image/...4C89974758220F
http://cfile30.uf.tistory.com/image/...4C8997485993C7
http://cfile29.uf.tistory.com/image/...4C8997485A8E68
i7-950 4GHz Overclock Test
http://cfile25.uf.tistory.com/origin...4C89974A609003
▲ intel Core i7 950 @ 4GHz / DDR3 @ 2000MHz 7-7-7-20 1T
1M Seuper PI
http://cfile22.uf.tistory.com/origin...4C89974B61B661
32M Seuper PI
http://cfile4.uf.tistory.com/origina...4C89974C635B99
PIFast
http://cfile3.uf.tistory.com/origina...4C89974C62CF50
Memory Benchmark
http://cfile6.uf.tistory.com/origina...4C89974D647A1A
MaxxMEM Benchmark
http://cfile25.uf.tistory.com/origin...4C89974D650817
wprime 32M / 1024M
http://cfile26.uf.tistory.com/origin...4C89974E662F2E
CINEBENCH R10
http://cfile25.uf.tistory.com/origin...4C89974E67609B
CINEBENCH R11.5
http://cfile9.uf.tistory.com/origina...4C89974F68E1B5
3Dmark Vantage
http://cfile7.uf.tistory.com/image/1...4C8997495E7ABE
i7-950 @ 4G Overclocking
cpu : 1.315
http://cfile4.uf.tistory.com/image/1...4C8997495D0FDB
http://cfile9.uf.tistory.com/origina...4C899750699900
http://cfile22.uf.tistory.com/image/...4C8997485B5DEA
IDLE : 241.5w
http://cfile2.uf.tistory.com/origina...4C8997516A76E4
http://cfile3.uf.tistory.com/image/1...4C8997495C2C2D
LOAD : 396.0w
Nice Pics 950 Low Voltage ;)
AMD OverClocker :D
Some LN2 Next Test :)
Hi, guys, has anyone had one or more of their memory channels disappear with this board? I’ve had my R2E for about a year and a half, along with my C0 920, but just recently started having problems. I’m currently running only 2 channels cause it won’t recognize the third slot (furthest from the cpu socket). I don’t think it’s a dimm issue as I’ve switched them around and it still happens. Are there some tests I could run? Memtest shows no errors in dual-channel mode.
You guys think it’s my 920 or my R2E, or another problem?
Thanks for your help.
i lost a slot after bending a cpu pin, worked once i found it and pulled it back into shape.
GoNz0, thanks for the tip. I loosened up on my mount and that seemed to make it a little bit better. After that, I found this site here.
Specifically, my QPI/DRAM voltage's relationship with my DRAM bus voltage was too large. So if you have the same problem, check that.
I plan on draining, cleaning, lapping my cpu, and doing a remount soon. I'll check for bent pins then and let you guys know.
I hope that helps someone!
I got almost the same problem here. I have 12gb, but ALWAYS when i turn my rig on it only reads 10gbs. So, i hit "del" to enter bios, wait for the bios screen to fully load and then i turn the computer off and right after that i turn it on again (not reset, turn off and turn on). That way it recognize all my 12gb.
btw i'm using a xeon x5650 on it.
ok for the ram disappear thingy
put all the dref voltage to +0mv
dont let it flux
awesome 2k c8 4gb on a x58 .. eh...result with so much pics.
Sounds familiar. Same thing, one slot would not work.
First off reset the CPU as the memory controller is integrated and this could be the problem.
Look for a bent pin in the memory slot.
I had RMAed the mobo because of a bent pin in the memory slot, but that didn't fix the problem (didn't tell them it was a bent pin as they won't warranty it). Recieved replacement mobo and still problems with that slot.
Talked with Asus tech. and he told me it was a shorting issue (after replacing CPU and mobo), how is that possible, it was working. So I pulled the board, put a piece of electrical tape on the mobo where each stand-off is screwed to the case.
Presto never had an issue since. Tech couldn't tell me why the mobo was shorting after working fine for a few months, but it worked. And hopefully will work for you.
John
Hi, John, thanks for letting us know. Mine appears to be working now, but I'll keep that in mind if I have more problems.
So back to this new beta BIOS, anyone try it?
Is it stable? Does it offer any more room for overclocking?
I'm afraid to try it out, sitting on 1802 :)
Yes, it seems stable. At least what was stable with 1802 is stable with 1913 (checked thoroughly with Prime96 64bit and Linx 64bit). I didn't try going further or lowering voltages with 1913.
But I'm a perfectionist and what literally kills me are typos that 1913 bios contains. For example, there is MODREN instead of MODERN in hints. :brick:
Say, what QPI voltage are you running on your CPU?
I was afraid to push mine further, got it at 4GHz at the moment and 1.325v, but the QPI is at 1.4v. If I drop it any lower it becomes unstable :(
Just wondering. I have a Xeon version of i7-920.
I need to replace my current cpu cooler. I have a TRUE but it is several years old and gotten pitted over time. Does anybody know if the Noctua D14 will fit this motherboard but not block all of the ram slots?
jesus crist, whats with the super size images, never heard of a plain old link instead of buggering up the forum layout :(
i have :
Intel Core i7 920 @ 4 Ghz 1.18v ( cooled by Swiftech Apogee GTZ, Laing Ultra + EK100,HW labs GTX 480 chrome + 8 fans), Asus Rampage 2 Extreme and Gigabyte X58-UD5, 3x2 GB Corsair Dominator GT 200 @ CL8 1.65v, Leadtek GTX285, SO Segate ST3250410AS + Storage Samsung 501LJ, Silver Power SP-S850 850W, DVD-RW Asus, Lian Li PC-A70B Moded, Asus VH242H 1080p, Windows 7 Ultimate x64
on ud5 i make 4.6 ghz on vantage with 1.51v bios ( 1.488v cpu-z and 1.49 on Multimetre)
on re2 i make 4.55 ghz on vantage cpu test with 1.475v bios (1.48 cpu-z and 1.52v multimetre)
if put 1.5v bios in load my cpu have 1.57v (multimetre) ... why board have this big overvolting ?? ...
My cpu need 1.51v>1.52v stable vcore for 4.6 ghz cpu test vantage ... and if i put 1.5v bios on re2 , mobo overvolt and my cpu have big temperatures >>> bsod
sry for my english
try with another bios version for r2e
i try 5>6 version bios and LLC Disable ... and no improvement
