Ye sure i will!
I´ve putten 2x40mm fans on top of them just to be on the safe side when messing with rams.
I suspect that somehow these pc1200 TX1200QLJ-2GK axerams are the plain and previous pc1066 with a new cooler packing, and thats it.
With the transcend axeram 1200 presently i´m really ram stable only on my 425x8 (which will be my starting point to go up) with auto divider, that means 1133 3:4 and the timmings at 5-5-5-15, 2.08 ram volt on 0903 bios (everest reports 2.16volt / vtt1.07) ccct and prime blend stable.
the next step whatever the divider is on this setup will be 1278 for the ram, tried that with 5-5-5-15 and 5-5-5-18 with no success, in fact i stopped when reaching 2.3 ram volt on bios (everest 2.4 / vtt 1.20), XP booting ok, apps running too but occt crashed after 3 minutes top.
And thats quite deep into the yellow area bios ram volt setting. Tried with different clocktwister and auto also, tried with trans. booster either auto or set to 2, or 0, no go.
I think i should use extra care when messing with ram voltage, because of electromigration, will cause your rams not to boot at stock settings anymore and progressively shorten their life.
just take a look in
http://www.xtremesystems.org/forums/...d.php?t=140870
in these very forums.
Unfortunately theres not much web info or testings with our particular rams, just found a chinese written one at
http://babelfish.altavista.com/babel...occ2%2f66.html
already with babelfish inserted into, but from what i saw there the guy can reach 1279 at 5-5-5-15 with 2.2V (i would guess in the bios right?) which somehow i cant (can you?)
Maybe bios 0903 is not so good on memory side of equation... i still wonder if asus took it out, must be for some reason on something unstable they found out. I bet they read these forums throughly, so they could also post the reasons why... to help us out getting the best of their hardware so in fact helping them!
Tell me what you´ve reached so far and at what bios voltings, i will keep on testing for stability and will post on results.
Has someone else spotted a transcend axeram TX1200QLJ-2GK OC test.? if so please let us know.
greets
