hobbs are those orange fans uv or are those leds in them
I had to add my precious to the gallery! My precioussssss...... :P She's a UFO Horizon that I worked on sporadically for a month or two until it was done. Definitely the best case out there! :up:
http://img505.imageshack.us/img505/7744/img0507jh1.jpg
http://img264.imageshack.us/img264/5960/img0510pr9.jpg
http://img100.imageshack.us/img100/8783/img0511aj1.jpg
http://img237.imageshack.us/img237/7493/img0513xd0.jpg
http://img150.imageshack.us/img150/8140/img0514zb4.jpg
http://img242.imageshack.us/img242/4406/img0524yb1.jpg
http://img72.imageshack.us/img72/7532/img0519pc0.jpg
http://img525.imageshack.us/img525/7519/img0518cy7.jpg
http://img160.imageshack.us/img160/9797/img0532pq7.jpg
hmm horizontal placement of EK multioption, i think i see a problem with cavitation happening...
RX7 - almost perfect except that white rad sticker sticks out like a sore thumb :)
GR8 - looks good, what is that at the top of your loop with the foam on top?
hdd cooler
@ arctic_storm: :eek: those hdds have any cooling? (ie: fan) they r sitting together so darn close & cuddly &... hot...
Whoa, Darth, that means a lot coming from someone that has a custom painted, phase chaged, gigantor UFO on steroids with a friggin axe sticking out of the top. Thanks! :)
I'm not too happy with the fact that the only air coming into the case has to pass through the PA120.3 first, so this morning I ordered a 120mm fan hole acrylic triple 5.25" bay cover from MM, along with a black 120mm grille, a Yate Loon D12SM-12, and some MX-1 TIM for the CPU to see if I get better temps than I get with AS5. My hope is that I can get some fresh air (that doesn't pass through a rad) into the bottom of the case for the PA 120.2 to take advantage of.
I just photochopped one of my pics and placed a 120mm in the left drive bay. What do you guys think?
http://img182.imageshack.us/img182/8...anfrontpm1.jpg
hmm mod horizon top to accomodate 2 120mm fans, or the 1 besides mobo (extra PSU slot) to another 120mm fan...
Septim, I want to keep the top with just the big window, as the motherboard and loops are the "showcase" of the entire setup. As far as the spare PSU hole, I wouldn't even know where to begin to throw a 120mm fan there and make it look good. :P
coolrmaster, how do you propose I get air into my case then? From everything I've read while deciding on a setup, the temperature of the air passing through the radiator doesn't really change. Running 3.65ghz @ 1.46V, I'm getting 33-35degC idle and 52-53 load. From what I've been told, those temps are excellent.
RX7, temps look good, what's the ambient?
I run qx6700 and 8800gtx sli at stock speeds on dtek fuzion and danger den blocks on single loop with pa120.3, temps approx. 8C and 20C above ambient respectively.
Ambient for me is anywhere between 20-22degC. If I set Vcore to Auto and clock down to stock speeds, my CPU idles at around 24-25degC and loads at around 33-35degC.
That's mine,I think with my QX6700 is not important to cool the NB couse you can't get more than 500-510 of fsb...
http://img102.imageshack.us/img102/6418/imgp0182xt5.jpg
http://img102.imageshack.us/img102/3219/imgp0183dz7.jpg
Painted the case flat black and added a second loop to accommodate the QX6700. Loops are as follows, PA120.3 -> Fuzion -> Microres -> DB-1 & MCR320 -> 2x EK FC8800 -> Microres -> DB-1
Also I replaced the stock asus p5n32-e sli heatsinks with thermalright HR-09's and HR-05's
http://i104.photobucket.com/albums/m...5/DSC00980.jpg
@ Roch: it looks sooo... sparse in ur case! i guess thats a testament to how clean it is ;) !
Nice, Roch.
Where did you get the black tygon tubing?
Thanks guys! :)
The Tygon came from Sidewinder computers, took about two weeks to post from the states, it's not the easiest to work with though.
