Is it me or does that reservoir look fat as hell? Looks really big.
Build looks awesome, simple design yet awesome;)
Thanks. And it's mainly deformation due to the roundness of the reservoir which makes it look fat, it's just a standard Bitspower reservoir :p:.
That exact statement made by one of my roommates was the basis of this case ;).
Unfortunately, not really. I have about 2 shots of the frame of the case, but nothing more. I might take it apart later, and 'fake' a buildlog ;).
The PSU sucks its air from the bottom compartement, mainly through some holes under the radiator, and through the hole for the harddrives, cooling them in turn. It gets a bit hotter than it did before, but nothing too concerning I think.
great ideas alexandros! looks very nice!
Very much impressed! What material is the main case structure made from?
Alexandr0s, for some reason your system reminds me of this http://www.million-dollar-pc.com/sys...-edelweiss.htm :D
Thanks guys for the comments :)!
@rubix: I used wood (mdf and spruce) for the entire structure. Great material to work with and great at absorbing vibrations.
@pcaddict: I actually used the concept to implement certain ideas. If I remember correctly, that case made me want to go with a vertical motherboard positioning instead of a horizontal one.
paoaudit:Outstanding work.
tipgo:nice job.I like it very much.It looks clean.:up:
Weird sleeving o_O Or is that stock sleeving xD
tipgo: Is that a SATA port above the GPU? What motherboard is that?!
tipgo: awesome build, one of the best mid-tower w/c builds i've seen. where is your pump located? and are you running 2nd 240 on top?
Aww man could you please give some more details on that build? :D
What radiator are you using at the top? I am wondering how thick it can be up there... Do you have fans on the top one?
How did you mount the rad in front?
I really like your tube working so minimal and everything just looks excellent, good job! :clap:
System Spec:
Coolermaster ATCs 840 Chassis x2
Intel X5650's
EVGA SR-2 Motherboard
EVGA GeForce GTX 480 Hydro Copper FTW - Quad Sli
12GB Crucial RAM
Kingston 64GB SSD's
Coolermaster Silent Pro Gold 1200w PSU
Watercooling Spec:
MIPS MB and RAM Freezer Blocks
Watercool HK3 CPU Blocks
Bitspower Carbon Black fittings
Phobya Radiators (2x 480 & 2x 240)
Koolance RP-450X2 Bay-Res x2
Laing D5 Pumps x3
Premochill 7/16" Hose
Premochill Dye Bombs UV Red
http://www.coolercases.co.uk/evga_sr...atcs_840_2.jpg
http://www.coolercases.co.uk/evga_sr...atcs_840_8.jpg
http://www.coolercases.co.uk/evga_sr...atcs_840_9.jpg
http://www.coolercases.co.uk/evga_sr...tcs_840_16.jpg
http://www.coolercases.co.uk/evga_sr...tcs_840_17.jpg
http://www.coolercases.co.uk/evga_sr...tcs_840_18.jpg
beautiful coolmiester....
stunning work :)
Great job man! :eek:
Awesome case! :clap:
@coolmiester..one of the best mods i have seen in long time,very clean
Holy Mother of C***** that is absolutely stunning Coolmester.
Coolmeistet, what an unbelievable build there mate, godly!
Outstanding coolmiester! I'm sure that added up $$$.
Awesome CoolerMeister! One of the best set ups I have EVER seen.
Here is mine, made a few changes to it. Mine cowers to the likes of Meister's but here it is anyways:
http://i409.photobucket.com/albums/p...g/IMG_2711.jpg
http://i409.photobucket.com/albums/p...1/IMG_2665.jpg
http://i409.photobucket.com/albums/p...g/IMG_2707.jpg
http://i409.photobucket.com/albums/p...g/IMG_2697.jpg
coolmiester: Amazing.............:shocked:. Really looks clean especially for that 56 pci lines.......:clap:
Coolmeister great case mate, Mind posting some more or even a log of the build ? :)
