Try using a 166 divider, (just try it) 11x, and raise up the HTT to get your speeds. I don't know why, but the ones I've tried and seen several others also, seem to prefer it.[IMG]http://img523.imageshack.us/img523/7...102144v1an.jpg[/IMG]
nice , which stepping?
i second that, thats amazing, only 1.4v and over 3ghz :clap:Quote:
Originally Posted by MARyo
Yes mine loves the 166 Divider as well I found out. Try it guys!
I second too :woot:Quote:
Originally Posted by XFxGeforced
What was the Vcore in order to run the chip @2.92Ghz?Quote:
Originally Posted by Fhqwhgads6680
My best air cooled under 1.5v on my 148
3150
Right now its at 1.59 v. I have homebuilt watercooling and my load temps are around 45-46c. I will post some screens soon with more info but right now im at work :( , I have a feeling its my ram cause not only is mt UTT REALLY finicky but I am also not yet used to the mem controller.
You was close to completely anticipate my second question... ;) What divider did you use? Did you ever tweak them appart from the CPU in order to see how they could really perform? Your combination of Geils' might take about 280MHz in 1:1 (if not higher)...Quote:
However, I have tested 2 weeks ago a good Opty 146 (CABYE0540APMW) which was able to do more than 3.1GHz under water and the improvement of the max bootable frequency was as follow:
MHz Volts
3170 1.71
3160 1.65
3150 1.59
3120 1.56
Sure there are not max stable values, but they give a good idea of the expectable improvement above let's say 1.60V (max stable frequency was 3118MHz @1.70V with 54°C during OCCT)... But your chip might be different, some love volts while other do not :D And it also depends on the cooling, but on some chips you could hit the wall even if you use a good air cooling.
Good luck; Let's see your screens...
hi guys, my new patriot pass the memtest 300mhz@cl2,5-4-3-7 1T only with 2.65v :D
>> http://img360.imageshack.us/img360/5...165v1fj.th.jpg
and finaly my configuration for 24/7 :
>> http://img247.imageshack.us/img247/1...a1006mn.th.jpg
and now after find stability at 3ghz its time to testing more , and for now 3200@1.60v:
>> http://img248.imageshack.us/img248/7637/32004lk.th.jpg
Mascaras that´s the best you can have,i dont think that putting de multiplier to 10 you're going to have any gain in performance.Quote:
Originally Posted by mascaras
A 32M run. :)
http://213.202.211.105/gravedigga/0546GPAW/22min32m.jpg
@MARyo, 0543fpmw. Nice job funkflix. :)
Hi, Just got opteron 144 0545 cpaw, put into my new dfi Ultra-d and the htt on the DFI does not go over 305, even if I give it 1.8 volts:( , and what is LTD,
Thx
wow, you're lucky your processor isn't a molten piece of silicon with 1.8v. LTD is a fancy way of saying HTT. You want to make sure the LDT multiplier keeps the HTT below 1GHz. If you leave it at Auto it'll go with the multi that the cpu designates. If the cpu supports 1GHz HTT then it will have a 5x multi and 305x5 is way too high for the processor to handle. Read the OC threads and guides thoroughly before doing anything more. You are really lucky you didn't fry your cpu at 1.8v.Quote:
Originally Posted by killer_pav
killer_pav (you don't get a nickname like that for no reason) :lol: :lol: :lol: :lol: :lol: :lol: :lol:Quote:
Originally Posted by MadMikeSS
No, I put the voltage of 1,8 on the chipset, not the CPU:nono:. Even if I put the LTD to 1 the htt does not go over 305Quote:
Alright, my mistake then. :) You didn't specify what you were giving 1.8v to and I assumed it was the cpu from your posting.Quote:
1,8 on chip7 ??? for what ????
tried 1,56 vs 1,7 on my DFI Expert, no change ;) (tested with 335 HTT which should be enough on my 148 :D )
just got an opteron 148 for the comp im building my friend. its a cabye 0542 fpmw, got a dfi nf4 sli-d and 2gb of g.skill ddr500. so i found the max htt of the board to be approx 350, the max ram to be like 270 and max ht to be 1200ish, but when i go to find the max cpu clock, this chip simply will not overclock at the 11x multiplier. it ran 350x8, but whenever i try to run it with 11x multiplier. it just refuses to post unless its at 200htt. anyone know why it might be doing this? hopefully i dont have similar problems with the 165 i just got for myself.
is 618-2 bios ok for opteron?
618-2 is just fine.
ejga :D
Got my 144 today. CAB2E 0546FPMW (same stepping as my 146, minus the week).
Does 2.7GHz on 1.45V! Not bad for a $230 CPU. :D
