an with my current rev, MCH is limited to 1.65 :/
is the Vmch the only difference between motherboard revisions ?
basically. maybe this is one of the reasons for the revision in the first place.
I am Facing this Slow Detection... ever since i got my board,when the Machine is Turned on,show the Ram Size,then there is almost 45 secs delay,after which only the device Detection ... comes over.First it detects the Usb Mouse
Wat could be the cause of the delay ?... Tried the Fixes Posted here nothing seems to work :mad:
Originally Posted by vinyas
clear cmos or flash to a newer bios.
dont think that will work.Quote:
Originally Posted by Bail_w
Here Is Screenshot:
http://img339.imageshack.us/img339/5...0050fk4.th.jpg
After the Delay,the Devices like My HDD & Writer Gets Detected
Try using the PCI LAN port (lowest or left most, depends how the board is oriented), in combination with some routers/switches the auto detect might go wrong...Quote:
Originally Posted by jikkyboy11
The PCI LAN controller seems to give me a lower cpu-load than the PCI-e LAN controller...
http://www.xtremesystems.org/forums/...06&postcount=1
For anyone that cares -- a replacement of my motherboard fixed problems listed earlier...
1901 blows.
1901 bios is fine
1901 wrking well for me
i am getting good results with 1901 (440FSB 1:1) , it just my ram was being a pita on this motherboard.
I had been using 1901 but had to flash back to 1707 today. It was ok and stable at first, but the past few days stability became a major issue. I was having system hangs and reboots and I wasn't orthos stable. I backed my overclock down and this didn't help at all. I flashed back to 1707 and all is fine.
Originally Posted by Psitech
what you use to flash it down to 1707?
afudos v2.17Quote:
ftp://dlsvr02.asus.com/pub/ASUS/mb/f...FUDOS_v217.zip
any instructions?
edit: nvm i got it.
wats the solution to this guys ?.... is this Problem listed on Page 1? .... i dont think so...if so,wr ?Quote:
help out pls
What's the problem? You just posted a pic of the POST...
If it's taking ages then the solution is on the front page
Guys, I don't know what happens, but after flashing the 1901 BIOS in, my RAM (thoroughly tested before) cannot run at 412 MHz with 4:4:4:12 latencies, under 2.20V any more! I'm getting BSODs, some intermittent software crashes, and the new (4-cores) Prime95 torture test fails with error, indicating hardware problems. My memory (Geil Ultra 800) used to run flawlessly with these settings for quite a long time; now I had to slow it down (the Prime95 test is stable with RAM at 388 MHz, 4:4:4:12, 2.0V).
Now, do you think it's the BIOS that's cusing this, or has one stick of my memory gone bad, or was the voltage (2.20V for DDR2-825MHz) not appropriate? TIA!
I've just been given Bios 2001 by a nice chap on MSN
I uploaded to Rapidshare: http://rapidshare.com/files/18038485...eluxe-2001.rar
PS: This is NOT tested yet by myself (exams), but apparently has been running for a week stable on this guy's rig
Hi, well I was foolish enough to try the 2001. Flashed up from 1901 ok with Asus Update, can't see any obvious changes and I can't see anything that would please any of you die-hards...
OneyedK, According to the bios, both the lan's are PCI-E...
ChrisC
any info ? bios 2001
upgraded from 1901 to 2001 with the flash utility in the bios.
Sorry, my bad, P5B-D in mind...Quote:
Originally Posted by cuke2u
apologies... :(
Im sure this has been mentioned in the last 162 pages :p: But I was just wondering a few things, as my friend just got this board the other day..........
1) In Asus Probe, is the "Motherboard" temp reading from the NB or SB??
2)What temp. should he try and keep them under??? Is 50C under load to high?
We replaced the stock NB and SB thermal compound with AS5, and are working on mounting a 40mm fan to the NB.
Thanks in advance :)
Any news on advanced timmings in bios 2001 ?
