The most interesting aspect of the Vertex4 is it's 128bit ECC. I wonder how it would fare in the endurance test.
Do they come in 60 GB flavors?
Todays update:
Intel X25-M G1 80GB
489.33 TiB
22204 hours
Reallocated sectors : 50 to 55
Available Reserved space: 96
MWI=67 to 66
MD5 =OK
43.61 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=485604
m4
667.4546 TiB
2869 hours
Avg speed 74.52 MiB/s.
AD gone from 230 to 227.
P/E 11578.
MD5 OK.
Reallocated sectors : 00
http://www.diskusjon.no/index.php?ap...tach_id=485603
Only 100 TiB until last m4 record is broken :D
Kingston SSDNow 40GB (X25-V)
860.08TB Host writes
Reallocated sectors : 05 41 // 1 up
Available Reserved Space : E8 99
POH 7729
MD5 OK
33.38MiB/s on avg (~141 hours)
I'm expecting Available Reserved Space [E8] to start decreasing. (as is the case on B.A.T's X25-M, no signs of that yet)
The drive will be offline until tonight, so it will be sort of a retention test. (it's just ~12 hours)
I wouldn't bother gettting the Petrol version. It is using Hynix H27UCG8T2MYR-BC and it appears to have a problem retaining data.
Post 7 onwards.
http://www.ocztechnologyforum.com/fo...028#post723028
(and there are plenty of other threads about bad blocks and data corruption, so I don’t think this is an isolated case).
Patriot Torqx-2 64GB - Day 54
Drive hours: 1,293 (722 Hours, 512 missing)
GiB written: 84,912 GiB (78.86 TiB)
Avg MB/s: 19.90 MB/s
MD5: OK
Bad blocks: 2 grown, 83 factory
Wear cycle counter: 5307 average erase cycles, 8133 maximum erase cycles.
Intel 520 60GB - Day 45
Drive hours: 1,092
Avg MB/s: 91.91 MB/s
MD5: OK
Host GB written (F1): 341,292.12 GiB (333.29 TiB, 10921348 raw)
NAND writes (F9): 241,644 GiB (235.98 TiB)
Reallocated sectors (05): 0
Failure count (AB, AC): 0 program, 0 erase
Media Wearout Indicator (E9): 22
Notes:
I have confirmation from Patriot on how to decode the smart values from the Torqx 2 - http://www.patriotmemory.com/forums/...0808#post50808
Looks like the Torqx 2 has fairly high WA in this torture test, which would explain it's low speeds.
Attachment 125201
@christopher
Did you record GiB written when WMI changed to 0?
Todays update:
Intel X25-M G1 80GB
493.02 TiB
22230 hours
Reallocated sectors : 55 to 64
MWI=66 to 65
MD5 =OK
43.51 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=485732
m4
673.9973 TiB
2895 hours
Avg speed 74.50 MiB/s.
AD gone from 227 to 223.
P/E 11689.
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=485733
the VT hit mwi 0 at 281 197GiB
Vertex Turbo
308373GiB
84.40 MB/s
AVG PE Count 5512
Samsung 830
544,535GiB
290.83 MB/s
PE Count 2386
MWI 33
Octane
248,260GiB
158.45MB/s
Todays update:
Intel X25-M G1 80GB
496.46 TiB
22254 hours
Reallocated sectors : 64 to 72
Available Reserved space: 96 to 95
MWI=243 to 236
MD5 =OK
43.42 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=485877
m4
680.0999 TiB
2919 hours
Avg speed 74.42 MiB/s.
AD gone from 223 to 219.
P/E 11793.
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=485878
OCZ Octane 128 Day 18
260,460.80 GiB
158.40 MB/s Average
Samsung 830 256 Day 25
566,875.63 GiB
290.60 MB/s Average
566 Hours
2483 Wear Leveling Count
MWI 32
0/0 Erase/Program Fail
OCZ Vertex Turbo 64 Day 43
314,914.13 GiB
84.40 MB/s Avg
1066 hours
5629 Avg PE count
100 MWI
0/0/0 Read/Program/Erase Fail
Attachment 125288
"WMI exhaustion" took it's time on the Vertex Turbo 64.
(GiB is about on par with the C300 64GB iirc)
865.46TB Host writes
POH 7775
MD5 OK
34.22MiB/s on avg (~46 hours)
The mini-retention test was not an issue. (12 hours 30 minutes)
Todays update:
Intel X25-M G1 80GB
499.68 TiB
22276 hours
Reallocated sectors : 72 to 78
Available Reserved space: 95
MWI=236 to 230
MD5 =OK
43.34 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=486029
m4
685.8411 TiB
2941 hours
AD gone from 219 to 216.
P/E 11890.
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=486030
True, but MWI for this drive should really be closer to 10,000PE-levels. Basically, twice the time to MWI exhaustion. For a contrast, I could always start running the 64GB Vertex EX, but I quite like that drive -- 50nm Samsung SLC and 100KPEs -- it's perhaps the finest incarnation of a Barefoot drive.
UPDATE -- ohh. The Octane popped some blocks sometime yesterday. It's reallocated sector count jumped from 0 to 4 and as a result MWI finally dropped from 100 to 97. My theory about reallocations and MWI seems to hold water. Since the MWI is only affected by bad blocks in the Octane, it's easier to see the relationship directly. But it was plain to see in the first Turbo I tried too.
It is somewhat troubling that it blew through 4 blocks at once, but I'd have to go back and check the logs to confirm.
OCZ is "looking into" the SMART data problems with the Octane and Petrol drives. Many users are suffering from the SMART data resetting and not working in general. Which is strange since there are so few attributes. I hope reallocations don't reset when the drive is power cycled like POH.
Patriot Torqx-2 64GB - Day 57
Drive hours: 1,366 (854 Hours, 512 missing)
GiB written: 89,856 GiB (87.75 TiB)
Avg MB/s: 19.69 MB/s
MD5: OK
Wear cycle counter: 5616 average erase cycles, 8611 maximum erase cycles.
I think I'll do a short retention test at 100TiB for this drive.
Intel 520 60GB - Day 48
Drive hours: 1,165
Avg MB/s: 92.63 MB/s
MD5: OK
Host GB written (F1): 365,016.50 GiB (356.46 TiB, 11680528 raw)
NAND writes (F9): 258,451 GiB (252.39 TiB)
Media Wearout Indicator (E9): 17
Okay -- the Octane looks like it has a problem. Reallocations are up to 8, MWI is now 93. This does not bode well for the future.
Update --- make that 12 reallocations -- maybe it only goes up 4 at a time?. I think it still looks sketchy either way, but there really isn't much detail.
Here is a somewhat useless chart I made. But I can confirm reallocations occur in twos. MWI is 91 with 12 reallocations.
Attachment 125299
Now that I think about it, the Octane seems to be getting slower while the other two trend upward in terms of Avg MB/s.
Todays update:
Intel X25-M G1 80GB
503.34 TiB
22300 hours
Reallocated sectors : 78 to 85
Available Reserved space: 95 to 94
MWI=230 to 224
MD5 =OK
45.71 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=486180
m4
690.8655 TiB
2966 hours
Avg speed 72.96 MiB/s.
AD gone from 216 to 213.
P/E 11981.
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=486181
My powercompany did some maintenance right after I went to work yesterday so both ssd got a 10h retention test and are working fine again after a restart of the test.
Drive hours: 1,389 (877 Hours, 512 missing)
GiB written: 91,456 GiB (89.31 TiB)
Avg MB/s: 19.67 MB/s
MD5: OK
Wear cycle counter: 5716 average erase cycles, 8772 maximum erase cycles.
Intel 520 60GB - Day 49
Drive hours: 1,188
Avg MB/s: 92.57 MB/s
MD5: OK
Host GB written (F1): 372,691.25 GiB (363.96 TiB, 11926120 raw)
NAND writes (F9): 263,889 GiB (257.70 TiB)
Media Wearout Indicator (E9): 15
Hmmm, I need another drive to kill, hopefully the 330 will be avaliable soon and not awful for killing.
Well, well, well. The Octane is not pleasing.
Reallocation: 28
MWI : 75
irritation index: high
On the other hand, I estimate the Octane to have used 2500 PE cycles. It is the frequency, not the number of reallocs, which makes me doubtful that Le Octane has a bright future. Its high time one of the three did something though. Its over a PiB written to the three drives and almost 11,000PE cycles between the three.
So much for NDurance. :rolleyes:
ECC and wear leveling have a new name... NDurance.
In the past 5 hours, reallocations have now reached 44 and MWI is now 62. At this rate, this drive could wake up dead before I get back home. I hope that doesn't happen... it has a nasty habit of locking up the rig.
Attachment 125308
E9 is MWI
E8 is total count of write sectors (which does not and never has worked)
05 is Reallocations (which, happen two at a time somewhat like the 830)
If you look at the timestamp in the chart above, the first reallocations happened around 50 hours ago. It's not that it's a lot in the grand scheme of it all, but it usually signals that the end is near. We'll see how it plays out.
Currently at 288,980GIB
Attachment 125309
I like this chart for showing MWI and reallocations
This quick degradation and death seems to be a recurring theme with ocz octane and petrol drives.
Definitely a bit early though.
More research is required.
