If your Vmod is giving you a higher GPU voltage, then you can forget the 100Kohm resistor from pin 3.Quote:
Originally Posted by cronic
If on the other hand your Vmod is not giving a higher GPU voltage, remove whatever you have done because it is connected to the wrong position, and connect the 100Kohm resistor to point 3.
To increase the current limit, increase the resistor value between point 10 and 11 by 50% by removing the old one and inserting a new resistor.
Attachment 44903[
