thanks :toast:Quote:
one is a true single core san diego, the other is a toledo with a core disabled ;)Quote:
Originally Posted by ManagHead
update @ 3000MHz 1.32V aircooled done yesterday.
i have some problem with my ram, can't get 273*11 stable but 10*300 yes, i tried all timings synch and asynch, vdimm... for tccd's but doesn't worked.
i'll resolve this problem when i'll have the time :)
http://membres.lycos.fr/starostise/K.../3000_1.32.JPG
Originally Posted by v0dka
my 0546 BPAW does also 3000MHz at stock volts.
nothing to mention.....
what about that?Quote:
Originally Posted by qujck
aircooled by freezer 64 pro
http://membres.lycos.fr/starostise/K...2004_1.32v.JPG
:D
Thats quite cool, but i only talked about the "3000MHz with stock volts" argument, and i never wanted to criticize your CPU. Its very nice :)
starostise: could you test the stability with Prime95? Really nice you habe there..is it with IHS on it?
why using prime95 instead of sp2004?Quote:
Originally Posted by BvK
the cpu is ihs modded, so it is with IHS on it :)
Kbg3e 0548 Cpbw
Daily "Prime95" approved:
(In-Large)
http://digilander.libero.it/m4puni/Sandy/23.jpg
(Blend)
http://digilander.libero.it/m4puni/Sandy/24.jpg
Here's my KAB7E 0547GPAW at 3080MHz on air:
http://img129.imageshack.us/img129/2...0mhz6tj.th.jpg
Damn... my Zalman sux... You have a TT, right?Quote:
Originally Posted by Monge
No, Arctic Cooling Freezer 64 Pro. But if I had to buy an aircooler today, I would go for the TT Sonic Tower or Big T with a stronger fan.Quote:
Originally Posted by Punisher!
Just my 2 cents.
Look here:
http://www.fan-x.de/testkcpu017_6.htm
But I'm going for High End watercooling now.
Damn... I discovered Arctic Cooling Freezer 64 Pro was better than Zalman after having bought it :(.Quote:
Mine will boot at 3.0Ghz but it isn't anywhere near stable, if I popped the IHS, would it be?
Hey Im new to the forums, I saw this thread and became interested so I joined.
Well I must have got a really crappy one. I cant get it to boot past 2.7ghz even with 1.55 volts. I have crappy memory and have to run a big divider so dont look at the superpi time. Any ideas on why mine willn't even get by 2.7ghz?
http://i21.photobucket.com/albums/b2...rclocking2.jpg
Wow, CPUz is reporting that voltage very very wrong.. I'd say try a new bios..
As far as my chip goes, it's kind've bum as well, KABYE 0536 GPMW.. It's volt hungry for sure..
http://cbaltzer.googlepages.com/29spi.JPG
Originally Posted by The Amish Kid
if I had a 3700+ that reaches 2.7 with that vcore I'd be happy!:D
then again... CPU-Z is for sure reading it wrong... so like haveblue said i should update your BIOS!
Yeah cpu-z is definitly reading it wrong. If you look at myguard that shows the real voltage. I will go see if there is a updated BIOS though
yeah those arn't bad clocks the 3ghz on air ones are just amazing.
haveblue, you need to be at 3ghz to get 29sec superPi 1m? theres something seriously wrong there whats your ram actually running at?
/Ed
Ram's divided down to run at (near) stock.. 408mhz I think it was. Timings are 3-3-3-8.. it's just cheap generic stuff.Quote:
Originally Posted by eddieate
hmm i guess thats it then, i cant remember exactly what i was getting 29sec runs at but i think it was under 2.8ghz which is what made me wonder about your score, nice chip you got there though where did you pick it up?
/Ed
Just from a local guy, not sure where he got it. Traded my 3800+ for it.. I don't regret it. lol :)
It's not really stable at 3.0ghz though.. made it through 3dMark05 the other day, but that was with the windows open to the cold Canadian winter.. nothing special for results though..
Must........resist.......buying.....3700+
Me and my pokey 3000+ at 2400mhz :(
very impressive.
so much for people being crazy about opties..
this beats the crap out of them.
