3000+ LBBLE 0517 APHW
http://valid.x86-secret.com/show_oc?id=21364
http://img.photobucket.com/albums/v5...2MB_158v-r.jpg
:toast:
:toast:
hımm it's not good as 0515 week and dpaw steping voltage is too high :slobber:Quote:
Originally Posted by NiCKE^
Yeah, pretty high voltage.
Good job there with the XE ErValt.
'Cause I'm greedy and I want to run 9*300 ;)Quote:
Not possible with this CPU at any voltage... Gonna see if burn-in helps anything or not.
Hmz, the burn-in helped me a lot. I'm down to 1.424v now at 2.7ghz. The cpu didn't want to do prime at 1.48/1.45 or anything close to it. Then I ran burn-in for less then 2 hours and I was able to prime at 1.45v I think. Ran 12h burn-in this night and now it works flawless on 1.424v ;)
CPU burn-in with what program?
It's called Cpu Burn-in :)
http://users.bigpond.net.au/cpuburn/
Ok!Quote:
http://koti.mbnet.fi/dani69/DFI%20nF...200517BPDW.jpg
StressPrime2004 2800MHz 1.5Vcore in BIOS for +2h
Dani, thats a good stepping.Quote:
Originally Posted by Dani
Do you use watercooling and what are your temps under load?
Modded VapoChill LS :cool:
Will see if I can get my to be 2,8ghz prime stable.
owh yeah its in your sig :D.Quote:
My goal is 2.8ghz@1.45-1.5V primestable.
how do you burn in ?
I got cpu burn in, toast , occt and s&m.
I prefer s&m for biggest heating but i don't know how i can run that program in loops.
Open Cpu Burn-in and let it run for 12h if you want "serious" burn-in but I ran it for 1h now and it made it a little bit more stable.
CPU BURN V1.01 ok ? ok i'm running it now
311*9 at 1.5v as i know it's prime rock stable....so i'll let it burn for next 9 hours when i go to sleep....
So i try tomorrow same settings with a little less vcore ???
But what if it reboots ?
Where to get S&M ?
StressPrime 1h stable for now 2853MHz @ 1.5V
Sounds good Dani!
Here is screenshot, it's time for clockgen now:fact:
http://koti.mbnet.fi/dani69/DFI%20nF...%201h30min.gif
Nice :) I never take screenshots on Prime anymore since it isnt 24/7 :)
Yep, and my Vapo+test rig is'nt 24/7 system :rolleyes:
dani which PSU do you have...your 12v line is over 12v, which is great....mine is always below 12v.....311*9 11.71-11.77 :(
Antec TrueControl 550W 20-pin.Quote:
Originally Posted by TEDY
+3.3 line at minimi, max around 3.96V :stick:
[offtopic]
were can I found MBM5 settings for my DFI nF4 Ultra-D :confused:
[/offtopic]
