hey any bh5/6 results and settings? I dont have tCCD to play with. NOT FAIR!
Originally Posted by situman
as u wish
mushkin pc 3200(heatspreaders not removed) 3.55 vddr 1.75 vtt timings in order from top to bottom
2-8-12-2-2-5-2-2-1-1 1t. I do not back off timings in order to acchieve higher speeds these timings are the best for performance and lowering them in order to gain mhz is kinda useless.
http://members.cox.net/italygirl25/bh-5%203200.bmp
is that a venice core? U dont seem to have the 1T issue and it seems to only effect the Venice or even the Sandy.
clawhammer :)Quote:
heres some more bh-5 same ddr speed higher clock to show you some nice scaling of performance with the timings i use. this memory is 100% stable at this speed with these timings looped memtest for a couple hours no errors
http://members.cox.net/italygirl25/more%20bh-5.bmp
i thought super tight timings are
2-7-12-2-2-5-2-2-1-1 1t
read write queue bypass 16x
bypass max 7x
max async latency 6ns
read preamble 5ns
sort of but im going by timings allowable in bios without a third party software.Quote:
Originally Posted by dinos22
sheik ill see your 266mhz and raise you 2 :)
timings by spd in bios swapped it to manual and left them what they were.
mushkin pc 3500 bh-5 heatspreaders still intact. I think ill take the heatspreaders off this set seeing how they seem to have more potential.
http://members.cox.net/italygirl25/3500@268mhz.bmp
shut the gates chew* is on a mission
awesome results....show us what the A64Tweakers settings are like there
Originally Posted by chew*
So far i able to build this source code as my A64 memory timing patcher through bios level...
Anybody have Dimm Dram Drive Strenght & Data Drive Stregth as DFI bios please let me know where it is located.. i'm not able to find it :(. Please correct me if you find any bug on my source code
I hope abit can add in more memory timing in future bios of this board... :(
ISA ROM Patch Source Code
Code:;---------------------------------------------------------------------
; tictac A64 Bios Tweaker Rev 001 Alpha
.486p
CSEG SEGMENT PARA PUBLIC USE16 'CODE'
ASSUME CS:CSEG
ORG 0
; Expansion PCI ROM Header
db 55h ; Rom signature byte 1
db 0AAh ; Rom signature byte 2
db 01h ; Rom Size (1bit = 512 bytes)
jmp INIT ;jump to initialization
; Address & Data Port
address equ 0CF8h ; Access to configuration address
data equ 0CFCh ; Access to configuration data
; PCI Bus, Device, Function, Register
; _________________________________________________________________
; | 28| 24| 20| 16| 12| 8| 4| 0| Bits Number
; |1 0 0 0|0 0 0 0|0 0 0 0 0 0 0 0|0 0 0 0|0 0 0 0|0 0 0 0|0 0 0 0| Bits
; |1 - - -|- - - -| Bus Number | Device |Func |Reg |- -| Definition
; |1 0 0 0|0 0 0 0|0 0 0 0 0 0 0 0|1 1 0 0 0|0 1 0|0 0 0 0 0 0|0 0| Bits
; | 8 | 0 | 0 0 | 24 | 2 | | 0 | Decimal
; | 8 | 0 | 0 0 | C | 2 | | | Hex
; |_______________________________________________________________|
dtl_add equ 08000C288h ; DRAM Timing Low
dth_add equ 08000C28Ch ; DRAM Timing High
dcl_add equ 08000C290h ; DRAM Configuration Low
dch_add equ 08000C294h ; DRAM Configuration High
ddr_add equ 08000C298h ; DRAM Delay Line Register
; DRAM Timing Low Address
; CAS Latency(dtl)
tcl_data equ 0FFFFFFF8h ; CAS Latency (3bit)
tcl_2 equ 000000001h ; CAS 2
tcl_25 equ 000000005h ; CAS 2.5
tcl_3 equ 000000002h ; CAS 3
; Row Cycle Time(dtl)
trc_data equ 0FFFFFF0Fh ; Row Cycle Time (4bit)
trc_7 equ 000000000h ;
trc_8 equ 000000010h ;
trc_9 equ 000000020h ;
trc_10 equ 000000030h ;
trc_11 equ 000000040h ;
trc_12 equ 000000050h ;
trc_13 equ 000000060h ;
trc_14 equ 000000070h ;
trc_15 equ 000000080h ;
trc_16 equ 000000090h ;
trc_17 equ 0000000A0h ;
trc_18 equ 0000000B0h ;
trc_19 equ 0000000C0h ;
trc_20 equ 0000000D0h ;
trc_21 equ 0000000E0h ;
trc_22 equ 0000000F0h ;
; Row Refresh Cycle Time(dtl)
trfc_data equ 0FFFFF0FFh ; Row Refresh Cycle Time (4bit)
trfc_9 equ 000000000h ;
trfc_10 equ 000000100h ;
trfc_11 equ 000000200h ;
trfc_12 equ 000000300h ;
trfc_13 equ 000000400h ;
trfc_14 equ 000000500h ;
trfc_15 equ 000000600h ;
trfc_16 equ 000000700h ;
trfc_17 equ 000000800h ;
trfc_18 equ 000000900h ;
trfc_19 equ 000000A00h ;
trfc_20 equ 000000B00h ;
trfc_21 equ 000000C00h ;
trfc_22 equ 000000D00h ;
trfc_23 equ 000000E00h ;
trfc_24 equ 000000F00h ;
; RAS to CAS Delay(dtl)
trcd_data equ 0FFFF8FFFh ; RAS to CAS Delay (3bit)
trcd_2 equ 000002000h ; 2 clock
trcd_3 equ 000003000h ; 3 clock
trcd_4 equ 000004000h ; 4 clock
trcd_5 equ 000005000h ; 5 clock
trcd_6 equ 000006000h ; 6 clock
; RAS to RAS Delay(dtl)
trrd_data equ 0FFF8FFFFh ; RAS to RAS Delay (3bit)
trrd_2 equ 000020000h ; 2 clock
trrd_3 equ 000030000h ; 3 clock
trrd_4 equ 000040000h ; 4 clock
; Min. RAS active time(dtl)
tras_data equ 0FF0FFFFFh ; Min. RAS active time (4bit)
tras_5 equ 000500000h ; 5 clock
tras_6 equ 000600000h ; 6 clock
tras_7 equ 000700000h ; 7 clock
tras_8 equ 000800000h ; 8 clock
tras_9 equ 000900000h ; 9 clock
tras_10 equ 000A00000h ; 10clock
tras_11 equ 000B00000h ; 11clock
tras_12 equ 000C00000h ; 12clock
tras_13 equ 000D00000h ; 13clock
tras_14 equ 000E00000h ; 14clock
tras_15 equ 000F00000h ; 15clock
; Row Precharge Time(dtl)
trp_data equ 0F8FFFFFFh ; Row Precharge Time (3bit)
trp_2 equ 002000000h ; 2 clock
trp_3 equ 003000000h ; 3 clock
trp_4 equ 004000000h ; 4 clock
trp_5 equ 005000000h ; 5 clock
trp_6 equ 006000000h ; 6 clock
; Write Recovery Time(dtl)
twr_data equ 0EFFFFFFFh ; Write Recovery Time (1bit)
twr_2 equ 000000000h ; 2 clock
twr_3 equ 010000000h ; 3 clock
; DRAM Timing High Address
; Write to read delay(dth)
twtr_data equ 0FFFFFFFEh ; Write to read delay (1bit)
twtr_1 equ 000000001h ; 1 clock
twtr_2 equ 000000002h ; 2 clock
; Read to write delay(dth)
trwt_data equ 0FFFFFF8Fh ; Read to write delay (3bit)
trwt_1 equ 000000000h ; 1 clock
trwt_2 equ 000000010h ; 2 clock
trwt_3 equ 000000020h ; 3 clock
trwt_4 equ 000000030h ; 4 clock
trwt_5 equ 000000040h ; 5 clock
trwt_6 equ 000000050h ; 6 clock
; Refresh Rate(dth)
tref_data equ 0FFFFE0FFh ; Refresh Rate (5bit)
tref_100_156 equ 000000000h ; 100MHz 15.6us
tref_133_156 equ 000000100h ; 133MHz 15.6us
tref_166_156 equ 000000200h ; 166MHz 15.6us
tref_200_156 equ 000000300h ; 200MHz 15.6us
tref_100_78 equ 000000800h ; 100MHz 7.8us
tref_133_78 equ 000000900h ; 133MHz 7.8us
tref_166_78 equ 000000A00h ; 166MHz 7.8us
tref_200_78 equ 000000B00h ; 200MHz 7.8us
tref_100_39 equ 000001000h ; 100MHz 3.9us
tref_133_39 equ 000001100h ; 133MHz 3.9us
tref_166_39 equ 000001200h ; 166MHz 3.9us
tref_200_39 equ 000001300h ; 200MHz 3.9us
; Write CAS latency(dth)
twcl_data equ 0FF8FFFFFh ; Write CAS latency (3bit)
twcl_1 equ 000000000h ; 1 clock
twcl_2 equ 000100000h ; 2 clock
; DRAM Configuration Low Address
; DLL Disabled(dcl)
dll_data equ 0FFFFFFFEh ; DLL disabled (1bit)
dll_enable equ 000000000h ; Enabled(default)
dll_disable equ 000000001h ; Disabled
; Dimm Drive Strength(dcl)
dds_data equ 0FFFFFFFDh ; Dimm Drive Strength (1bit)
dds_normal equ 000000000h ; (Default)
dds_weak equ 000000002h ; (Beware)
; Read/Write Qued Bypass(dcl)
rwqbp_data equ 0FFFF3FFFh ; Read/Write Qued Bypass (2bit)
rwqbp_2x equ 000000000h ; 2x
rwqbp_4x equ 000004000h ; 4x
rwqbp_8x equ 000008000h ; 8x
rwqbp_16x equ 00000C000h ; 16x
; Bypass Max(dcl)
bpm_data equ 0F1FFFFFFh ; Bypass Max (3bit)
bpm_0x equ 000000000h ; 0x (Disabled)
bpm_1x equ 002000000h ; 1x
bpm_2x equ 004000000h ; 2x
bpm_3x equ 006000000h ; 3x
bpm_4x equ 008000000h ; 4x
bpm_5x equ 00A000000h ; 5x
bpm_6x equ 00C000000h ; 6x
bpm_7x equ 00E000000h ; 7x
; Command Rate(dcl)
cr_data equ 0EFFFFFFFh ; Command Rate (1bit)
cr_1t equ 000000000h ; 1T
cr_2t equ 010000000h ; 2T
; DRAM Configuration High Address
; Maximum Async Latency(dch)
async_data equ 0FFFFFFF0h ; Maximum Async Latency (4bit)
async_0 equ 000000000h ; 0 ns
async_1 equ 000000001h ; 1 ns
async_2 equ 000000002h ; 2 ns
async_3 equ 000000003h ; 3 ns
async_4 equ 000000004h ; 4 ns
async_5 equ 000000005h ; 5 ns
async_6 equ 000000006h ; 6 ns
async_7 equ 000000007h ; 7 ns
async_8 equ 000000008h ; 8 ns
async_9 equ 000000009h ; 9 ns
async_10 equ 00000000Ah ; 10ns
async_11 equ 00000000Bh ; 11ns
async_12 equ 00000000Ch ; 12ns
async_13 equ 00000000Dh ; 13ns
async_14 equ 00000000Eh ; 14ns
async_15 equ 00000000Fh ; 15ns
; Read Preamble(dch)
rp_data equ 0FFFFF0FFh ; Read Preamble (4bit)
rp_20 equ 000000000h ; 2.0ns
rp_25 equ 000000100h ; 2.5ns
rp_30 equ 000000200h ; 3.0ns
rp_35 equ 000000300h ; 3.5ns
rp_40 equ 000000400h ; 4.0ns
rp_45 equ 000000500h ; 4.5ns
rp_50 equ 000000600h ; 5.0ns
rp_55 equ 000000700h ; 5.5ns
rp_60 equ 000000800h ; 6.0ns
rp_65 equ 000000900h ; 6.5ns
rp_70 equ 000000A00h ; 7.0ns
rp_75 equ 000000B00h ; 7.5ns
rp_80 equ 000000C00h ; 8.0ns
rp_85 equ 000000D00h ; 8.5ns
rp_90 equ 000000E00h ; 9.0ns
rp_95 equ 000000F00h ; 9.5ns
; Idle Cycle Limit(dch)
icl_data equ 0FFF8FFFFh ; Idle Cycle Limit (3bit)
icl_0 equ 000000000h ; 0 clock
icl_4 equ 000010000h ; 4 clock
icl_8 equ 000020000h ; 8 clock
icl_16 equ 000030000h ; 16clock
icl_32 equ 000040000h ; 32clock
icl_64 equ 000050000h ; 64clock
icl_128 equ 000060000h ; 128clock
icl_256 equ 000070000h ; 256clock
; Dynamic idle cycle counter enable(dch)
dicc_data equ 0FFF7FFFFh ; Dynamic idle cycle limit (1bit)
dicc_disable equ 000000000h ; disabled
dicc_enable equ 000080000h ; enabled
; Memory Clock Frequency(dch)
mcf_data equ 0FF8FFFFFh ; Memory Clock Frequency (3bit)
mcf_100 equ 000000000h ; 100MHz
mcf_133 equ 000200000h ; 133MHz
mcf_166 equ 000500000h ; 166MHz
mcf_200 equ 000700000h ; 200MHz (1:1)
; DRAM DQS Delay Line Register
; DQS Slew Value(ddr)
dqs_data equ 0FF00FFFFh ; Delay Line Adjust (8bit)
dqs_1 equ 000010000h ; 1
dqs_2 equ 000020000h ; 2
dqs_3 equ 000030000h ; 3
dqs_4 equ 000040000h ; 4
dqs_5 equ 000050000h ; 5
dqs_6 equ 000060000h ; 6
dqs_7 equ 000070000h ; 7
dqs_8 equ 000080000h ; 8
dqs_9 equ 000090000h ; 9
dqs_10 equ 0000A0000h ; 10
dqs_255 equ 000FF0000h ; 255
; DQS Slew Control(ddr)
dqsc_data equ 0FCFFFFFFh ; Adjust DQS (1bit) & (1bit)
dqsc_slow equ 001000000h ; Slower DQS
dqsc_fast equ 002000000h ; Faster DQS
; Sub Routine
ORG 100h
SAVE1 PROC NEAR ; Save all register that will be affected by our code
push eax
push ebx
push edx
pushfd
ret
SAVE1 ENDP
SENDER PROC NEAR ; Active communication with address
mov dx,address
out dx,eax
ret
SENDER ENDP
RECEIVER PROC NEAR ; Comunicate with the address & receive the data
mov dx,address
out dx,eax
mov dx,data
in eax,dx
ret
RECEIVER ENDP
TUNER1 PROC NEAR ; Sending new data from ebx stack
xchg eax,ebx
out dx,eax
xchg eax,ebx
ret
TUNER1 ENDP
TUNER2 PROC NEAR ; Increase data (OR)
or eax,ebx
out dx,eax
ret
TUNER2 ENDP
TUNER3 PROC NEAR ; Decrease data (AND)
and eax,ebx
out dx,eax
ret
TUNER3 ENDP
RETURN1 PROC NEAR ; Restore register contents and return far to system
popfd
pop edx
pop ebx
pop eax
retf
RETURN1 ENDP
RETURN2 PROC NEAR ; Restore register contents and return to SATA bios
popfd
pop edx
pop ebx
pop eax
retf
RETURN2 ENDP
; Main Routine
INIT PROC NEAR
; save all register that will be affected by our code
call SAVE1
; trc = 13
mov eax,dtl_add
mov ebx,trc_13
call RECEIVER
and eax,trc_data
call TUNER2
; trfc = 15
mov eax,dtl_add
mov ebx,trfc_15
call RECEIVER
and eax,trfc_data
call TUNER2
; END Patch back to system bios or SATA jump (RETURN1 = System ; RETURN2 = SATA jump)
call RETURN2
INIT ENDP
ORG 200h
CSEG ENDS
END
AN8 Ultra : nForce4 Ultra + Silent OTES Heatpipe + 7.1 Audio (Max Vdimm 3.55V
is that a good solution? it s stable enough that motherboard? :p:
that was the board i was going to get however it was unavailable so i got the sli board and currently hold all 3 records for an abit overclock on them . stable enough for you?Quote:
Originally Posted by blueangelman
figured id make a note of this for everyone.
ddrv undervolt by .05 so in order to run tccd at 3.0 volts set vddr to 3.05 and vtt to 1.5v
TicTac i think that Data Drive Stregth in DFI bios set the Memory DQ Drive Strength field in DRAM Configuration High Address (bits 13-14).Quote:
Originally Posted by tictac
I suggest you to take into account all possible combinations of the refresh cycle in your tweaker. About Tref i think the bits in the Refresh Rate field of the DRAM Timing High Register are encoded in this way:
Bits 12-11 are the refresh cycle in us:
00 -> 15.6 us
01 -> 7.8 us
10 - > 3.9 us
11 -> 1.95 us
Bits 10-8 are the MemFreq where the refresh cycle selected in Bits 12-11 is given. These Bits are encoded like the DRAM MEMCLK Frequency field in the DRAM Configuration High Register:
000b = 100 MHz
001b = 120 Mhz
010b = 133 MHz
011b = 140 Mhz
100b = 150 Mhz
101b = 166 MHz
110b = 180 Mhz
111b = 200 MHz
However on the Abit Board you can select 216, 233 and 250 Ram Freq (through the bit 30 of the DRAM Configuration High Register i think), so we have:
000b = 100 MHz
001b = 216 Mhz
010b = 133 MHz
011b = 233 Mhz
100b = 250 Mhz
101b = 166 MHz
110b = 180 Mhz
111b = 200 MHz
anyone live near rhode island that wants to temporarily donate a venice for me to test to confirm that its a cpu microcode issue as to why 1 t isnt working for them? should have mushkin utt redline results soon waiting to borrow it off a friend.
What would that mean? That the board will always have issues with 1T & Venice or would an update to the CPUs or BIOS be needed? I really wanted that combo. :(Quote:
Some ppl do have issues with 1T & Venice (like me... :() and the latest bios (1.5) doesn´t help at all...
well it appears i am one of the few people that has high fsb/ w 1t command rate without issues. It would also appear that i am one of the few that is using a clawhammer. That would mean that A. everyone has a cruddy venice or sandy which i doubt B. everyone has a bad board and mine is just cherry which i also doubt or C. the cpu microcode in the bios isn't optimized for those cpu's yet.Quote:
Originally Posted by Psyche911
Don´t get me wrong... i love this motherboard, and i know Abit will do it´s jog right, it´s just a matter of time. Chew* what are your temps?
damn i have a week 17 venice and a Storm G5 waiting at home,but I have to be the family chauffer today. DAMN IT!!!! O yea and new AN8 SLI hoping this will resolve the 1T issue. Good thing Newegg has a good return policy
is this kind of undervolting considered severe or acceptable or normal?Quote:
inaccurate at best abit eq says 117f on average. Mind you i have a asetek waterchill pro and i run this cpu at 2.4 gig at default volts for 24/7 use. there is no way a asetek 3x120 radiator setup with fans on high is running at those temps.Quote:
Originally Posted by ukveld
kinda normal considering if you do a 3.3v rail mod you need 3.4-3.5v for the memory to see 3.3vQuote:
@chew*
you can update microcode using cbrom xxxxx.bin /cpucode cpucode.bin
take it from latest DFI nF4 615 BIOS
chew - depends on the mod.
a .05v undervolt on load is acceptable when 3.3=vdimm, but any more than that and there are problems.
tccd performance versus bh-5 on an8
tccd @ 300mhz timings 2.5-9-14-4-2-6-3-2-2-3-1t
bh-5 @ 240mhz timings 2-8-12-2-2-5-2-2-1-1-1t
clock speed of cpu is 2400mhz in both tests. I used this as an average overclock of what most people will see as a 100% stable overclock.
tccd
http://members.cox.net/italygirl25/t...comparison.bmp
bh-5
http://members.cox.net/italygirl25/b...comparison.bmp
as you can see the tccd manages to barely edge out the bh-5 in all tests but the performance difference is minimal. the choice is obvious for those with a weak memory controller and those already having bh-5 i wouldnt suggest going out and buying tccd.
