^^ what he said... but nice looking chip! mine will do 3ghz with 1.475 vcore, but I can't prime with that voltage... then anything over 1.50 would cause too much heat, so I popped the top and that did the trick.. hopefully you won't have to go through that with yours... the new ones seem to be better with vcore it seems... as the fabrication process optimzes.. they get better yeilds of good chips which need less power.. the KAB3E's were good OCers also.. well, a bunch of them... anyways... post more info on your OCing when you can. :)
