I've got both chips here right now... an original 3500+ Newcastle and the new caa2c 3500+ Newcastle, I'm going to test them both out on air, water and phase this weekend... hope the new caa2c clocks well :)
gocchin, may you prove me right! PLS! I got the 2600+ sempron this weekend, myself.
It would be interesting to see a comparison of the NC and this new one running at same clocks, I wonder if there would be a difference?Quote:
Originally Posted by gocchin
Well as you know HiJon89, I do a lot of benching so I'll try running superpi and pifast as well as bench 3dmark with identical systems only swapping out the cpu....Quote:
Originally Posted by HiJon89
Totally same as yours.
Except for the serial no. :D
I've also done some tests with a XP-90 + chilled air cooling
(I opened the windows in my room. :D )
and got it prime stable at 2.8G with vcore 1.6V :)
Originally Posted by sauria
can you do one at stock, so that we get a 754 comparo in there as well? 3500+ is 3400+ w/dual channel, AFAIK...Quote:
must be the chilled air cooling that gets u extra 0.2G :DQuote:
Originally Posted by formyfaith
I am most definitely hitting a wall at 2600, everything after that is unstable and increasing the voltage does nothing. I can do 2600 @ 1.58V though. It's odd that even up to 1.7V I can't gain any stability. Could it be my memory or board? I always reduce everything to isolate it down to the CPU itself... at least I thought so!
you've probably just hit a brick wall on that chip...Quote:
Originally Posted by Ackbar
same as the 3500+ i had from chiefvalue...
stable up to 2.6 but no matter how many more volts i put in, i couldn't gain any more...
Managed to run a cool PI score for this chip :D
http://img.photobucket.com/albums/v1...chmarks/27.jpg
what kind of temps is everyone running these chips up to? my xp-120 is working as good as i thought it would with this chip...if i go over the 1.55 voltage mark my temps are going into the 60c range and i cante keep it stable. anyone else with similar results?
Originally Posted by Veedo
I'm seeing about the same thing with an XP120, above 1.65v the temps start really climbing.
I'm at 250x10 for 2500mhz with stock volts 1.49-1.50 with a temp of 43-45c.
270x10 for 2700mhz with 1.71v was 58-60c but is not prime95 stable.
I'm running my memory at 227 with 1t at 2700mhz and I don't know if its my memory thats erroring out. OCZ3700EB, but I read that its not so great in the MSI NEO2.
Using the stock HSF and AS5 at 2600mhz and 1.456v, i see 43-44C idle, and when prime blending i hit 58-59C. Guess its time to start looking into a XP-120 or a watercooled system
Prime failed after 2 hours at stock. Now that is odd.
these arn't looking so great all of a sudden :(
The only benefit for me is that I can run 10x255@1.55v........I think. Whereas on my winnie, I had to run 10x250 w/5:4 for the mem. My FX-53 wouldn't even thing of running over 10x245 at any voltage. So for me, yeah, it was worth the money. But I'll be buying a venice ASAP. I want that 11x255.Quote:
Originally Posted by kryptobs2000
:( Me wants 2.7
yeah what the hell happened? the first posts we saw on these chips they were hitting 2.8-2.9 consistently :stick: I still have hope though since mine is at 2.6 on stock volts :)
OT: Does anyone know of a sticky/FAQ that explains all the different settings of the DFI mobo? Im losing my mind trying to get them all straight!
I couldn't run my 3700eb over 220 in my neo2 without errors.Quote:
Originally Posted by RacerX27
Mine does 2620Mhz stable at stock vcore. Max stable is 2720Mhz 1.64v. Watercooled by a crappy BigWater set. 59-60c load.Quote:
Originally Posted by boostdfd3s
I was hoping for 2800 stable when i saw 2600+ at 1.5v .. but no :(
is it safe to run 1.6V 24/7. Will that reduce long term life on tyhese chips or is 1.55V the max you'd want to run? Or do these not respond to voltage increases as wel las some other chips?
it's all about the heat. 10c will halves life expectation of most electronic components...could be the SMD's that die before the silicon does.
Normally i feed my chips anywhere from 1.6 to 1.9v .. haven“t killed one yet. The procs can take 1.7 and 1.8 just fine as long as your temps are fine.Quote:
Originally Posted by Magnj
I tortured this chip a litte while i was at work. 1.75v prime smallFFT for about 10 Hours. Running at 70c :D
Maybe I reduced the liftime with 3-4 years.. but who cares. Its not like im gonna be using this more than 5-6 (tops) months anyway :)
I say kill the NewCastles and Clawhammers.. lets get Venice or San Diego :banana:
Formann your evil.
This PC needs to last probably 4-5 years. So im thinking 1.9V = not a good idea :P.
So volts in a resonable range are ok as long as temps in Spec? 60-65C right?
Evil? No .. reckless.. maybe :shrug: :p:Quote:
1.55-1.6v should be just fine with those temps. Of course the best would be if temps were below 60c .. like 50-55c. But 60-65c should be okay.
