I was talking about diameter...
Wider is better, not taller.
that's why you gotta keep that tire low profile, not to exceed the diameter of the total length...
Wider is not better.. Being wide is what will slow down.. :D
some 18" wheel w/ only 7.5" deep and low skinny low profile tire(P205) won't slow you down.. it'll be just as good if not better. The benefit you'll get is stiffer and more responsive ride. :p:
Sure a wider wheel means more weight. But adding diameter is worse, as it adds more rotational weight...think of the centrifugal force. The faster that wheel spins the more that weight is worth.Quote:
Originally Posted by IamAnoobieCheez
And you want to add more rubber and less wheel, not the other way around. Wider tires help grip in corners and I can guarantee you my 275/40/17 and 315/35/17 Nittos have more grip than anything you have on your car. There is really only one benefit to larger diameter wheels, and that's looks. I won't debate that, but everything else is a downside. You will lose acceleration, mileage, and traction ;)
Not to mention the price of tires.
That's why you gotta get lighter wheels!!!
and actually.... not only was I pointing about the weight, but being "wider" makes "more" contact on the road which slows down your car also.
Your tires are too wide and fat. you don't wanna go too wide:slapass:
You may think so, but I don't. And try telling that to people who actually race and they will tell you to get off the message boards and get some time with a real car...
my uncle used to work for ford rally( back in days of jimmy McRae) nad he explained the whole thing to me about tires.
basically soulburner and iamanoobiecheez, u r both rite.ideally u want ur tires as narrow as possible whilst still maintainiing suitable traction for the level of power. the 450bhp sierra cossies were using 16's which were 8.25inch wide.
more contact in with the ground will loose u acceleration but too little will loose u traction.the ligther the car, the more narrow tires u can get away with.
btw wats ur deffinition of "people who actually race". cos sure thingsl ike nascarr u want wide ass tires to get all that power to the ground but sometihng like WRC u want more narrow tires so that it can actually turn.
It also depends on the application. For a road race car you want a straight, stiff sidewall. For a drag race, that will only work against you. You want a fat, tall tire for more "squishyness" so to speak. A tire can't bite and twist if it's too hard on the sidewall. Often times increasing the wheel diameter, forces you to run lower profile tires and only hinders your traction.
its a gift from my mom :D so I can avoid saving money for now and spend it on computer partsQuote:
Originally Posted by Soulburner
Mazda 2 Neo ATM
http://www.mazda.com.au/mazda2/artic...m2_neo_lrg.jpg
Might transist to a Mazda 3 SP23 once the deal is done today :)
http://www.mazda.com.au/mazda3/artic...ue2004_lrg.jpg
http://img326.imageshack.us/img326/6...61sm8oz.th.jpg
I like my 1993 Mercury Cougar XR7 V8 and I also think the Mitsu VR4 is a nice car. But I like wide tires.... Mostly I like rear drive with comfy seats.
SHiZNiLTi's Slow Xtreme...
http://i113.photobucket.com/albums/n...th_XtremeG.jpg
The Blaza...
http://img83.imageshack.us/img83/2149/pic31ep.jpg
The Motor...
http://img205.imageshack.us/img205/5749/motorwk1.jpg
The Bass...
http://img205.imageshack.us/img205/5817/glossybu1.jpg
SPECS:
~20" 312'S on 255/35/20
~K&N Air Filter
~Modded Air Flow Sensor with resistor off ebay
~Poweraid throttle Body Spacer
~Hypertech Programmer
~Pully Kit
~JBA Headers
~2.5" Down Pipe
~3" pipe all the way back
~Hi-Flow Cat
~2 Chamber 50 series Flowmaster
~BIG 3 Upgrade
~1 Optima Yellow Top
~260 Amp Irragi Alternator
~0 gauge power cable to amp
~8000k HID's HELLA BRIGHT!!!!
~Pioneer AVIC-N1 GPS w/6.5" Flipout LCD
~Rockford Fosgate t30001cd 3758rms amp
~18" Fi BTL subwoofer / (2) 15" ******?
~Gloss black enclosure 5 cubes @ 34hz / 8 cubes 33hz
~160GB modded USB HD w/ every NES, SNES, N64 game loaded on it and 80GB DVD :banana::banana::banana::banana: rips
My best upgrade has got to be when I tinted my entire front windshield with
35% and all of the side's and rear with double 5%(limo tint) No tickets for a
year and a half now and absolutly no visablity into the car from almost any
angle.
My subwoofer enlcosure design log...
I'm starting the paint job, so far I've rounded all the edges of the box and sanded it
using 80 grit and slopped some wood filer on all the cut edges. After the wood filler
dries I'll smooth it down with 230 grit and begin the primer stage by brushing it on.
- Miniwax Sanding Sealer Primer(brush on)
- 4 cans of Gloss Black Lacquer for wood
- 1 can automotive clear
- Elmers wood filler
10/15/06
http://img116.imageshack.us/img116/4...liesoo1.th.jpg
http://img116.imageshack.us/img116/9...llerpr1.th.jpg
http://img116.imageshack.us/img116/5...ndedvj6.th.jpg
http://img292.imageshack.us/img292/9188/boxzs8.th.jpg
10/16/06
1st Primer Coat, mdf hella sucked it right up...
http://img116.imageshack.us/img116/2...oat1qk1.th.jpg
10/17/06
2nd coat of primer...
http://img292.imageshack.us/img292/1543/box2ww6.th.jpg
10/18/06
3rd coat of primer and it's not soaking in anymore, I think its gonna be an excellent
surface to apply my Gloss Black Wood Lacquer. I'm gonna do another coat of
primer tonight and then tomorrow after work I will debate what I should do...
http://img116.imageshack.us/img116/9...coatir1.th.jpg
http://img116.imageshack.us/img116/3...oat2fr6.th.jpg
10/19/06
4th coat of gloss black lacquer
and it's getting to be a really solid gloss black, but I have a few wavy lines that I'm
not sure how to take care of and I really need some help or recomendations on
what to do...
Black Lacquer ...
http://img221.imageshack.us/img221/2092/coat4an0.th.jpg
http://img221.imageshack.us/img221/4153/coat4oc4.th.jpg
10/20/06
I figured out the best way to get rid of the lines and that is to wetsand the box.
I got the supplies and will start wet sanding the box tommorow if the box is cured
enough....
http://img167.imageshack.us/img167/2...tuffdg2.th.jpg
http://img167.imageshack.us/img167/2931/paperzo1.th.jpg
http://img167.imageshack.us/img167/7...oundtg1.th.jpg
10/26/06
Finished product, still gotta make a video :D
http://img166.imageshack.us/img166/5594/trunkfarlf3.jpg
11/11/06
Wetsanded the box with 2000grit for a ultra glossy mirror finish...
http://img205.imageshack.us/img205/2...andgoodtq7.jpg
Pics from 06/12/06...
http://img83.imageshack.us/img83/9761/pic58nh.jpg
http://img83.imageshack.us/img83/2028/pic62dj.jpg
Hi-Rez Pics...
http://img83.imageshack.us/img83/752/pic23jv.jpg
http://img83.imageshack.us/img83/2888/pic10cq.jpg
http://img83.imageshack.us/img83/6070/pic41qc.jpg
11/18/06
Smoking with Window Tint Paint for model cars....
http://img206.imageshack.us/img206/7...ture023xi8.jpg
http://img206.imageshack.us/img206/1...ture021ty4.jpg
They look solid black, but when you hit the breaks the red LED's shine brightly through the paint for a pretty cool effect :D
I smoked my headlights using (2) cans of window tint paint....
http://img292.imageshack.us/img292/2...dlight2iv2.jpg
http://img292.imageshack.us/img292/1...dlight3kv9.jpg
http://img292.imageshack.us/img292/4...dlight4no5.jpg
3M Buffing Compound is needed if I want a glossy look to them.
The Bar...
http://img292.imageshack.us/img292/1600/alc213ii2.jpg
¤¤*UPDATE*¤¤
I just added the new box to my computers sound system. I've got optical out from a X-Fi Platnium card to a Harmon Kardon AVR reciever sending a hella clean signal to the JL. Having a computer to adjust the sound of the bass makes this thing move some air and sound amazing.
Click to play...
http://img54.imageshack.us/img54/7999/jlvideops1.jpg
I've only got the volume up a tad and it still moves hella air :P
I'm using the amp in the HSU MK 2 to power the JL sub...
VTF-2 MK 2 250rms...
http://www.hsustore.com/vtf2.html
http://img294.imageshack.us/img294/4061/chair1az4.jpg
http://img294.imageshack.us/img294/5195/chair2dd8.jpg
http://img294.imageshack.us/img294/5030/28hzid9.jpg
01/22/07
6.7 cubes @ 31hz with 100sq.in. of port. for a 18" Fi BTL sub that can handle 5000watts. This should be loud enough to do half of what this does...
http://www.realmofexcursion.com/vide...am/xxx15.1.wmv
Still need to make another front for the double baffle, after that I'm going to round the port and all the edges of the box with my router and begin putting it together with wood glue and my pneumatic nail gun.
http://img224.imageshack.us/img224/3402/workarea6as.jpg
http://img224.imageshack.us/img224/2708/19high2wh.jpg
http://img224.imageshack.us/img224/2601/26long6cu.jpg
http://img224.imageshack.us/img224/8940/37long5ri.jpg
http://img224.imageshack.us/img224/3093/topview7om.jpg
http://img215.imageshack.us/img215/7515/191908292tn.jpg
http://img215.imageshack.us/img215/5464/678784324bf.jpg
http://img215.imageshack.us/img215/4585/964296884gi.jpg
I decided to place the sub on the front and double baffle it. I have another section of 1¼" dowel left so I may add some more bracing from top to bottom, think I need it?...
http://img209.imageshack.us/img209/4...view7om3af.jpg
I'm using a Planet Audio thats birthsheet is 2257rms @ 1ohm ...
http://img221.imageshack.us/img221/1467/goo2us1.jpg
This lil cordless saw is great, i used it to make the 45 wegde in the corner...
http://img209.imageshack.us/img209/5073/saw4bo.jpg
I was planing on painting the port today, but the weather is really crappy!
It was nice a sunny this afternoon, then this happened...
http://img397.imageshack.us/img397/5...udywind8ti.jpg
Either I've got a really bad case of dandruff or it was hailing outisde...
http://img397.imageshack.us/img397/5466/hail2ga.jpg
I did manage to primer (2) pcs of the port before the weather turned to hell...
http://img397.imageshack.us/img397/3841/primer7fm.jpg+
Not sure when www.Ficaraudio.com will ship the sub, hopefully I will get it by Friday, but since it's being custom made with a triple stack magnet and an advanced cooling system and every other option it takes a while.
I work 8-5 M-F, here's my tasklist...
- Tonight I'm going to round the edges of the port and outside of the box.
- Tuesday or Wendsday I'll probably make the double baffle that's going to cover the entire front of the box, I will also have to make a cutout for the port.
- Thursday I will wood glue and nail the box together.
- Friday I will sand and get most of the prep work done to paint the box.
- Saturday - Sunday I will start the procedures of painting the entire box.
I got the 18" Fi BTL in and wow is it heavy almost 70lbs just for the sub.
1.5" thick front, used a circular saw to make cutout hole for the port...
http://img201.imageshack.us/img201/9...ebaffleal7.jpg
http://img262.imageshack.us/img262/4306/btl1hd1.jpg
http://img262.imageshack.us/img262/5343/btl2mq5.jpg
http://img176.imageshack.us/img176/8849/btl3na2.jpg
http://img176.imageshack.us/img176/4008/btl4wa2.jpg
http://img261.imageshack.us/img261/8438/btl5no3.jpg
my jigsaw cutout...
http://img225.imageshack.us/img225/3872/cutoutmk2.jpg
http://img225.imageshack.us/img225/4866/newbtl2kp8.jpg
http://img225.imageshack.us/img225/8...wbtlpicay0.jpg
http://img225.imageshack.us/img225/2339/newpicxd4.jpg
http://img479.imageshack.us/img479/9724/btlout1wz5.jpg
http://img479.imageshack.us/img479/539/btlout6xa2.jpg
http://img479.imageshack.us/img479/5028/btlout3dy4.jpg
http://img479.imageshack.us/img479/1984/btlout2ze2.jpg
http://media.putfile.com/18--Fi-BTL
http://img479.imageshack.us/img479/2...optionsxk4.jpg
Here's some pics of my Rockford Fosgate Power T30001bd that I just picked up for only $500 which retails for $2000...
It does 3758rms @ 1 ohm...
http://img481.imageshack.us/img481/4...edpowercj2.jpg
It's almost as wide as my 7cuft box for my 18" BTL...
http://img481.imageshack.us/img481/3756/onblazertp2.jpg
The box is half the height of my truck...
http://img481.imageshack.us/img481/8366/ampboxbu2.jpg
Size comparison to 16oz Rockstar...
http://img481.imageshack.us/img481/4...leclearwc8.jpg
Size comparison with Razr Cell...
http://img481.imageshack.us/img481/5...llphonejp7.jpg
Tight fit up the stairs, its hella long...
http://img481.imageshack.us/img481/6954/stairsir2.jpg
On the office chair...
http://img481.imageshack.us/img481/4531/onchairtb8.jpg
It's very clean...
http://img481.imageshack.us/img481/2213/shinnyji6.jpg
LOL, the guy in the video that drove up to me came from about 1/4 to 1/2 a mile away. He said that he was sitting at his dinner table trying eating and his window was vibrating. I tried to get the entire thing on tape, but only got the last half. At first he said what the hell is that and what are you doing. He was very impressed with teh sub and is a pretty cool guy be being resonable and not being punk....
http://www.youtube.com/watch?v=MGyeLjU-iig
http://i113.photobucket.com/albums/n...th_BTLVID3.jpg
http://i113.photobucket.com/albums/n...racingwall.jpg
http://i113.photobucket.com/albums/n.../th_REMT18.jpg
http://i113.photobucket.com/albums/n...etupinside.jpg
http://img149.imageshack.us/img149/7944/subsinpn1.jpg
http://img220.imageshack.us/img220/8...bsontopgq0.jpg
http://img149.imageshack.us/img149/2...goingindq3.jpg
http://img149.imageshack.us/img149/9404/mt18sincu9.jpg
Check out The Ultimate PC Setup....
http://img120.imageshack.us/img120/7...ncrtsfkpx9.gif
http://www.twistedforums.com/forums/...36&postcount=1
@SHiZNiLTi nice motors
more pictures of the toyota
Should change that to say, no visibility into OR out of, the car from any angle...
Well, as the pictures tell, you can see in and out of the windshield just fine. My friend has a 06 Civic Si with the same limo tint setup and during the day its annoying, and at night all you see are little dots for headlights.Quote:
The windshield yeah, but I was talking about the other windows. I'm doing 35% on my windshield.
That should look really nice on you vehicle Soulburner.Quote:
Have you guys ever noticed how in the commercials for cars they allways have the front window tinted... check it out all but the VW do it I think.
I actually have 5% limo on the sides and back and (2) layers of Huper Optik 40% film also on the side and rear windows.
The Huper Optik film is what we used for the Mercedes dealer that I managed a tint shop for. I've got about $1400 worth of film on here. Just (1) 40% layer of Huper Optik has 70% heat rejection! and I have (2) layers of it and Limo :D
This is my first car, that I bought for myself.
I bought it for my 21st birthday present. HPPYBDAY2MELOLZOMG!!!
http://www.nelp.net/slayer/cars/ride/side.jpg
But this is my true first car, given to me on my 18th B-day from Mom.
http://www.nelp.net/slayer/cars/rim1.jpg
I have the 2006 Civic Si, and here is a pic on the day I took delivery.
http://img39.imageshack.us/img39/3111/myciv49ny.jpg
My 1996 Eclipse GSX, i love it to death!
http://img86.imageshack.us/img86/609/p10101965og.th.jpg
http://img86.imageshack.us/img86/728...01971tx.th.jpg
New 3" exhaust is what i'm planning..
http://img49.imageshack.us/img49/502...01983ls.th.jpg
Manifold will be painted... eventually. New intake sometime next month too.
http://img86.imageshack.us/img86/149...01999ao.th.jpg
camaro 95 and a dodge caravan
04 Civic. I live in a college town, it really is so generic. One time there were 3 civics in front of me and two behind! But it's a stick shift and saves me a boatload on gas!
1988 Ford Orion 1.6D :rolleyes:
185/R15, custom dark blue paint (unique simply because the idiot who made the paint mixed it into a white paint bucket - but wtf, it's unique :slap: ), engine built ground-up in 2004. Had alloy rims but in .ro we have crappy roads... so crappy that they were fuxed up after only 10000km :slapass: - so I switched back to plain iron Mondeo rims.
60bhp, 4.5l to 5l @100km. Pretty neat considering that I don't use my car for racing but only for going to school and sometimes seaside/mountain :D
I have this car:
http://www.toyota-club.by/images/323vscorolla/p-2.jpg
http://www.toyota-club.by/images/323vscorolla/p-4.jpg
http://www.toyota-club.by/images/323vscorolla/p-6.jpg
Only different color (grey). 12 year old, 200k km, 90pk.
1300cc :( damm slow toy :slapass:
2006 Pontiac GTO & 2006 Ford Explorer (Hauler / Billboard)
http://img20.imageshack.us/img20/496...07075726fv.jpg
http://img20.imageshack.us/img20/346...07677261vv.jpg
