Nice scores there! :toast:Quote:
Originally Posted by FROG
How far can you get with approved drivers?
make a new guess :DQuote:
by the way 12745 is not bad
Considering Shimano did 12,900 with 66.93 without an FX-55 and similar video clocking, I would assume that you could easily eclipse 13K. So, how about 13,145? As a start, anyway ;)Quote:
Originally Posted by macci
With the newer drivers, I could see you getting close to 14K.
i made a mark03 test and got 14769 but in the details says that my 6600gt are clocked...299mhz!!!what should i do??
It's just futuremark, it doesn't detect it properly , dont worry, use rivatuner to clock then u know they are set :)
anyway i liked the old 66.93 drivers from this point of view!they were giving no trouble!
12.9k? I remember seeing 'only' 12.4k? That's 500marks difference - which one is right? :DQuote:
edit: according to this it was 12457 @ 600/1300, 3080MHz
13145p is my guess. Keep on rocking Finland! :D
Macci, any 03 runs?
Maybe it was 28,900 on 03 that I recall (just found result on ORB for 28,994, never could find the 05 result). The 05 result was not published after the version update. But, I guess a good place to verify the 05 score is his very own site. I should have took a peak over there. Either way, looks like you crushed that score. 12,900 or 12,457 ! :slobber:Quote:
Awesome Macci... I am working on it still need better cooling on the cores still learning...I can't seem to get my cores over 520 not sure if it is temps ( Most likely) or just tweakingQuote:
So most of you guys well in the 12,4xx range and higher are using LN2 for cooling????Quote:
520 is pretty much the limit with standard cooling (chilled water, etc). You need to move to a more extreme cooling method to get more clocks. I have bumped into the 520 core limit on more than a few Ultra's with chilled water.Quote:
Yep your right as I found out yesterday. I have some big pelts but not sure of room... Have asked about Phased unit for SLIQuote:
Originally Posted by dwwalker14335
Well, with some encouragement from watching OPP I managed to get some colder temps onto my cards as well. I'm pleased. It resulted in some good increases and net my two new best scores. :banana:
05: 12,843 http://service.futuremark.com/compare?3dm05=741239
03: 27.598 http://service.futuremark.com/compare?2k3=3865712
These were done with the 71,84 whql drivers. I'll try the old 66.93 ORB approved drivers this weekend.
Very nice.. Great job and with 71.84's Hope you'll share how you were able to get them to OC.... I found some issues and cleaned up a volt mod and just ran this...3d05 12,516
I have not ran 03 yet and made a nice 37k+ run at 2k1..
Good deal Mike:)Quote:
Originally Posted by mdzcpa
How much Core Hz did you gain?
OPP
my god those the same cards as before ? :)Quote:
Yep! Same pair:DQuote:
Originally Posted by eva2000
Like you I gained about 30mhz. I went from 490mhz to 520mhz.Quote:
Originally Posted by OPPAINTER
Your doing a great job selling those cards even before you list them. ;) Are they still going to be listed at aQuote:
Unlike OPP's cards still no volt mods right?Quote:
..and we have a winner! :DQuote:
or it can be 13045...please tell me
13,045. Incredible. Anywhere we can read in detail about this score?
Yes please. And maybe a picture of all the mods to the boards?
I have a bunch of pics from the 'Team Finland' OC session on my home-pc. I'll try to get something posted over at akiba-pc.com :)
Macci and Team Finland Congrat's thats alot of talent in a room at one time, no Offense to the bunch of guys overall at the TX ati event, but these are the guys that are the elite in the World!!!
Was picking up 30MHz just from cooling or a combo of cooling and the 71.84's?Quote:
