Yes those are total, next to it you will see weekly top users and daily top users.
These are the XS stats
updated every 6 hours. :)
No.. the stats update every hour... the nodes upload every 6.Quote:
Originally Posted by heater918
http://fotki.lv/?x=OS5RKFxDRy06RDxIU...06RjxIUkJRTVY=
Lil problem...
Stats not uploding...
When you look at the status screen.... are any of the task failing?
When you check your CPU utilization in the task manager, does it show 100%?
Of course 100% i run D2OL with normal priority instead low.
Nothing goes wrong..
When you look at the agent window (The fancy java GUI) Can you see if it has any task queued (Task assigned and task downloaded)??? In the upper right... does it say "Docking candidate", and "Computing Docking Energy for Conformer #x"??
Yes, there all OK.
yestarday i turn off firewall too, but it doesn't help.
when do my cadidates upload? after its compleated the 200 assigned tasks?
thanks, Ed
they upload every six hours or so. Or when you go into the status and click manual uplaod.Quote:
Originally Posted by eddieate
also any idea how macs perform? my 1.5ghz G4 has done 4 Cands in about the time it took my venice to do 30+
thanks again, Ed
I am not sure how they compare. But you may be able to give us some insight on the matter.
And just to help out with a little advice. You want to set your queue size to 2000. This will help keep you in work in case their server goes down over a weekend or the like.
Rod, anyone,
I've just installed 2 x nodes using the EZ installer.
Being the tool that I am I forgot to write down the numbers of the nodes!
Please someone tell me that there is an easy way to find them out?!
open up the clients.... the node id's are on the top right ;)
I tried that sort of thing already, from what i can see the two potential files for launching the clients would be D2OL.exe or Launch D2OL Agent.exe. Double clicking either of these appears to do nothing.Quote:
Originally Posted by Korpse
I figured it was because the EZ Installer has configured the clients to run as services that it's not so easy just to fire up the clients.
Maybe if I kill the processes first and then try to run Launch D2OL Agent.exe?
that works, or you can go to your page at d2ol.com and click on the "My Nodes" link along the top. Your nodes will their numbers next to them on the list.
Haha! You underestimate my incompitence! I haven't even got as far as registering the nodes yet! I tried to register and then realised that the registration process asks me for the node ids!Quote:
Originally Posted by DragonOrta
I got the thing running on my machine at work with the intention of leaving it running over the weekend and then sorting out all the registering etc after the weekend - that should teach me to try and think on a Friday afternoon!
EDIT:
I think it just doesn't like me. I killed the processes & found my node IDs & tried to register. It said it can't find the nodes. I then deleted node.prp in case I screwed something up the first time.
Started things again and entered my email address again, got 2 new node IDs. Thought I haad it but no! Again it tells me it can't find my nodes.
So I figured it maybe just didn't know I was there yet - I manually updated it so that both nodes uploaded a task result. Still nothing. A node search tells me that it's not there.
Can anyone help? :confused:
My node IDs are 123081 and 123082 if it helps at all.
i'm alos working through a proxy but the client tells me everything is fine :confused:
EDIT AGAIN:
:banana:
Now it decides to work! It even remebered to 373 cands that it ran over the weekend on the previous node IDs that I thought I had lost.
Now I think I might just leave myself unassigned to a team and wait till New Years time to assign them all to XS!
Thanks for trying to help guys, most appreciated :toast:
great to hear that you got it all figured out there. I was about to offer to send you one of my node.prp :D
Well I decided to start crunching away for xs d2ol
Got 4 nodes right now, I'll have d2ol on a tumbdrive so any computer I come accross its going on it.
Welcome :toast:
Sweet, we should have a famous quote section,Quote:
From entityQuote:
OC every single piece of hardware you can put your hands on, slap D2OL on it and proceed to the next piece of hardware
Question:
Just started D2OL on a dual Opteron 280. I'm running four processes, each on one core. They max out all my processors but my other applications are running with a little glitch (no biggie here). I'm just concerned about a thing... I hate to lose a 1400 bucks processor or both for being maxed out 24/7. How bad will it be for the lifespan of a processor? How likely is it for them to crap out?
http://www.insanelabs.com/images/maxedout.jpg
i havn't heard of any processors dieing because of it. just make sure they are properly cooled and they should be fine.
i think you need to have maybe helheim's xtremewatchdog or d2oldaddy installed also. i keep hearing everyone else say xtremewatchdog works better as a service than d2oldaddy.
nice system btw :)
The reason hellheim's program works better than d2ol daddy is because hellheims was built to run as a service, where as d2ol daddy is a stand alone program. As far as how long the cpu will last, as long as it is properly cooled (lower than 60c) and u arent pumping insane amounts of voltage (>1.7) you should be fine. Thank you for running d2ol. How much does the opteron rig pump out a day?
No worries QettoE.....those chips are designed to run at full blast in a hotter environment than what you're in I'm sure, AMD nor Intel would make a chip that couldn't run at full speed 24/7. And if you want to make sure your other apps get precedent....restart your system, it'll restart with the D2OL apps as a service forced at the lowest priority.
Good question, you might be able to tell me what I'm doing here as well since I can't make any sense of it yet (been pretty damn busy to look it up, and I'm lazy too!).Quote:
Originally Posted by moddolicous
http://www.insanelabs.com/images/d2ol-1.jpg
A few more things... I'm running the services through FireDaemon because my registry wasn't patched properly for some reason (2k3 x64 maybe), but either way they max out. I'm also running D2OLDaddy as a service to watch over my processes.
This is a 1U rackmount server colocated at Level(3) data center, but it's not as cool as other places that I've been in. This barebone has six 15000RPM fans blowing directly at two passive heatsinks but I have no way of knowing the exact temperature because Tyan doesn't come with a tool to do such thing. Maybe I can find a software to monitor them later on.
Q.
U can give motherboard monitor a try, or speedfan to check the temps. There are 4 different nodes, right?? So u should be doing (4*88=352) 352 daily if that was the full day. What do they run stock??
