didn't do superpi... i'll try it later today :) on 1m? or 32m? or other? :)
Some Primeaction! :)
http://people.freenet.de/funkflix/prime2830.jpg
http://people.freenet.de/funkflix/prime28302.jpg
Maybe it works with less Vcore, but i've not tested it! I'm tired
of Prime ... hours of waiting! ;)
pfff i borrowed a friend his 2 x 256 mb noname cl3 :S what a drama, can't even get my system bus on 270 with 100mhz divider somehow... :S i'll do superpi tomorrow, if i'll have my ram back then ;)
Here's early days....but it seems I'm hitting a wall at 270HTT with tight timings..... clock too low with the 250fsb, and 270HTT too low to get better than 35sec 1M SuperPI. Gonna have to get a 3200 for the 10 multi.....
Originally Posted by GravediggA
Nice, but my 90nm always errors P95 at about 3.5hrs tops. Run it all night for us.
Thanks!
AndyOCZ, you said all night??? ;) how about 15hrs ???
http://www.xtremesystems.org/forums/...1&postcount=91
Here is mine... not too bad I guess, but Always room for improvement...
2.8ghz - http://www.sevenlabs.net/a64/2.8.jpg
2.75ghz - http://www.sevenlabs.net/a64/2.75.jpg
2.7ghz - http://www.sevenlabs.net/a64/3000.jpg
2.6ghz with 1:1 - http://www.sevenlabs.net/a64/2.6_memory_TCCD.jpg
Originally Posted by bachus_anonym
GROOVY BABY!!! :banana4:
I guess the week 41's may be the good stuff. The earlier ones are not running P95 Blend at all from what I have seen.
Thanks.
GOLI what week is your chip, and is it stable at that speed?
I don´t know what week is my chip, but when i take off the waterblock tomorrow i will tell you, now i am full stable at 2750Mhz but i have some error in Everest home edition and Sandra i don´t know why, anyone knows?Quote:
Originally Posted by stelleg151
here are some SS:
http://img125.exs.cx/img125/2333/cpuz3zn.th.jpg
http://img125.exs.cx/img125/8162/everest7zv.th.jpg
http://img125.exs.cx/img125/7898/sandra4qj.th.jpg
http://img125.exs.cx/img125/9928/sup...tral1ya.th.jpg
Anybody have the same thing, that is showing some errors in some softwares?
Goli is that ram at 1T?
sure ... 2T want be 32sek pi!
hehe 2T at 32s, htt = 400? :)
has anyone got this combination working effectively yet. i have heard their is a beta bios out to sort the low temps problems with Winchester cores on the MSI board. If anyone has got a winni working at sub zero please post a solution
Yes is 1TQuote:
Ok now i have the stepping of my chip how i know what week it is?
ADA3000DIK4BI
CBBFD 0441SPMw
1077009K40333
your chip is made in te 41st week, 2004
(0441) - my chip is 0437
i'll be sitting on the edge on my chair waiting for your adventure with Winnie + Neo2 :) hopefully i'll be putting mine under phase change soon so need to see your experiences with this setup...Quote:
Originally Posted by pc ice
@goli,
which waterblock you got? and what are your temps?
thnx.
wah is the maximum stable with you cpu with 1,6v @air?
can you say me your full stepping?
Originally Posted by amilian
I have custom waterblocks made it by me and a friend of mine, here are some pics of my waterblocks, i have a temp of 45° full load at 1.65V core with a room temp of 27.
http://www.watercooling.cl/modules/n...php?storyid=62
There are some of my blocks :D
Nice work and nice temp.Quote:
Originally Posted by Goli
Which retail block would yours currently equate to? I'm trying to get an idea of how my Maze 3 would do, and how well a Zalman7000 air solution would compete with water at 1.65vcore at the same clock speed.
Thanks.
I don´t know very well, here in Chile we didn´t have any retail watercooling system to test, so is dificult to compare my waterblock with some other one.Quote:
With the Zalman 7000 maybe you can reach 2700Mhz and a CPU temp of 50-55 full load think.
OK, thanks for that estimate. I'm thinking about the same, and that it's not going to be good enough for this chip. It likes temps under 50. I think I'll put my watercooling on it as soon as I get the right block.....my maze 3 doesn't fit.....Quote:
Anyone know a good mod for it to make it fit?
